Freezers Logo
Anonymous Posted on Nov 28, 2011
Red light whirlpool freezer - Whirlpool Freezers
Model UW8FDXB1EX Whirlpool Upright freezer
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
2helpful
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
I have a whirlpool chest freezer wcn9-1. & its condensating really bad causing puddles. Can I stop it? There is a button at the front low down that sticks out & glows red when out. If its pushed in...
check your gaskets. If the gaskets don't make a tight seal it can condensate close to the gaskets. the red light indicator light more than likely refers to a moisture control and it should be on.
3helpful
We got a philips whirlpool chest freezer my husband pressed orange button as he was told it was turbo boost freezers only cold at bottom and red light is on
Orange switch only by passes the thermostat. It sounds like your freezer is either out of gas or the cooling fan (if there is one) is not working.
My whirlpool afb 6640 freezer has a red light on
thermostat is defective(loose contact)
May 09, 2009 • Freezers
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
