I can connect my computer with a DVI to HDMI gold plated Cable to all ports and receive signal, but my Blu-Ray, X-Box 360, and Dish Network Satellite will no longer receive signal on Ports 2-4, they work just fine on Port 1 though. I thought maybe the cables were bad at first but all the cables that didn't work on ports 2-4 worked great on port 1. Then I thought it may have been the HDMI Ports on the TV that were bad, but my computer connected to all 4 ports just fine. Have you ever encountered this situation and do you have any idea what could be the problem? I just ordered a 6ft Gold Plated HDMI cable with hopes that maybe the cable being gold plated is the reason my computer still works.
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
SOURCE: my hannspree tv wont turn on i hav tryd switchin it off at mains
Hi
maube you have lost contact in your remote wiring! please check the remote area and power oscillation area.
Thanks!
SOURCE: My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
SOURCE: can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
SOURCE: Something to make soft solder blend in more to gold color jewelry
Was looking for a patina - used in stained glass - this is what others suggest...
"I use gold leaf paint at my solder points in
a stained glass piece to make it look like brass. Have repaired many
pieces and used the gold leaf paint and works very well. I think the
paint works better than the gold pen."
Gold'ish color at least - hope this helps... Dan
Testimonial: "Thank you. I will try that "
I'm not really sure why it says (K206-10U1-005) at the top but The model is listed in the Bold Print.
Again, any solutions would be welcomed, and hopefully I can get it fixed without having to ship the TV off.
Seems that I fixed it by completely unplugging the entire unit for 10 minutes, then unplugged all hdmi cables and after 10 minutes plugged everything back in and powered the tv on and it worked.
