I used self cleaning mode it worked fine door unlocked but now when i try to use the oven the red door latch light flashes and oven nor broiler will work it will go back into self cleaning mode though
First check the door is locked in place , even its closed properly and the light flashes then you may need to replace the door switch on the oven ......
Good luck...
The range thinks the door is not fully unlocked. This occurs most often when the door latch is moved (ie: someone tries to open the oven door) before the oven has cooled enough. This results in a slight bending of the door latch bar, and the door latch switch is not satisfied. Generally, you have to get to the door latch mechanism from the top side, under the stove top, remove the latch assembly, bend the door latching lever back slightly into it's original shape, and reinstall.
After you cancel the self-clean cycle, just press and hold the light
switch; the "locking mechanism" resets itself and then the door will
close. Otherwise you may have to open up the panel and disconnect
the "locking arm" to reset it.
let me know if neither of these work
See to it the there was no stuck object or parts on the door parts...
was not the latch but the switch itself is bad thankyou,only have to rember to take burner screws out first nextime as bent burner gas supply tubes,no problem though,again thank you! :)
Cleaning oven pulled door off can't get it back on
