Samsung PS-50B530 50 in. HDTV-Ready Plasma TV Logo
Anonymous Posted on Nov 27, 2011
Is there any default parental pin lock for this tv?
Hi A few days ago i unplug the antena to move the forniture when i plugged it back it ask me for a parental lock pin number,, i never set it, is there any default number for this tv?? thanks
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Dec 12, 2011
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071909
Points
27242
The default pin # 0000
  • Anonymous Dec 12, 2011
    thanks , i tried that one but it says invalid
Parental lock code
Most tv's can be reset when you unplug them. Unplug the tv and let it set for about 30 min and plug it back in. This should reset the code to factory default of 0000.
1helpful
2answers
2answers
How to unlock parental control in Airtel digital tv?
i want to reset my airtel digital tv parental password
Turned on parental lock do not have password
check tv manual for factory setting password
9helpful
4answers
Have a vizio tv and an input locked messages appeared and turned the tv off . Now when you turn the tv on the tv shuts off. How can we fix this? We unplugged the tv and pressed the side . We plugged the...
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the side of the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV
6- Power the TV back on
The tv has locked and is asking for a pin code to unlock it but i don't have it ?
It could be that the CHILD LOCK is engaged.
Try 0000 or 1234.
Then use the menu to turn it off.
Otherwise unplug the power cord and leave it out for a few hours to clear the internal memory and reset to default settings.
Good luck and please post back with how you make out.
1helpful
Need to set parental control pin
This TV calls it "V-Chip". Code is "0000" by default.
1. go to TV User Menu
2. select "TV" menu
3. selct "V-Chip"
4. change this to a lower setting
Help K2001UM TV
I'ts possible that by accident someone activated the parental lockout. Your best bet is to locate your instruction manual and find the default code. Also problems(usually with software) can cause the the tv to do unusual things. Leave the set unplugged for at least 24 hours, the see if there is a response with the buttons on the tv. You may be able to reset the set to factory defaults. Scrivitron
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
