Hi - Just tried to print a few photos with a few odd colours - daughter's purple skirt came out a sick green colour, and the grass in the background looked purple - the rest seemed OK. Tried changing colour profiles etc, printing from other software, changing print quality - same. Just out of curiosity, did a colour copy of the sick coloured image - and it came out correct - ie the colours that were wrong on the image that I was copying ended up correct on the copied image. ? Bit weird - not a proper HP cartridge, but had others previously which were fine. Many thanks
SOURCE: Excessive Yellow ink use
Issue
The
printer is working, but the colors in the printed output are not the
expected colors. The output may look as if only one color has printed,
or as if a color has not printed, or as if the wrong colors have been
printed.
Solution
Complete the following steps to resolve this issue.
Step one: Check ink levels
If
the print defect is minor, it might be caused by reserve mode
operation. When the printer runs out of some colors, it can continue
printing using remaining inks, but print quality may be affected. If
cyan, magenta, or yellow is out, the printer can print only in
grayscale.
NOTE:
HP
cannot guarantee the quality or reliability of non-HP ink. If ink
cartridges have been refilled, try replacing them with genuine HP ink
cartridges.
Replace any empty print cartridges.
To access the ink level gauge, follow these steps.
Step two: Calibrate the color
If the cartridges have not been refilled and none are empty, try calibrating the color.
Step three: Clean the printhead
If the steps above did not help, clean the printhead.
Step four: Contact HP
If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
SOURCE: No PRINTOUT, only blank page/ no page received
Dear Teleios
'power button blinking without taking a paper to copy' usually means paper jam or no ink error.
First ensure you have no paper jam and you just replaced both ink cartridges.
If the printer still does not print, or does not print colors or black ink, then the ink must have dried up on printer head/nozzles.
You can try using clean nozzles option from hp printer software several times, and see if this fixes the problem. If it does not you will need to physically clean printer heads inside with solvent and cotton. To do this you need to disassemble part of the printer.
Having same work done in a service centre should cost around 50 euros.
HP DeskJet 3820 InkJet is not an expensive printer, if you cannot fix it with a clean head / nozzles from software you may also consider buying a new one for slightly more than the price of a cartridge change.
Regards
SOURCE: Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
SOURCE: HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
SOURCE: Just refilled the ink cartridges on my HP
If you do a lot of printing you may wish to look at an option such as this
http://cgi.ebay.com/Continuous-Ink-supply-system-Hp-74-75-CB335WN-CB337WN_W0QQitemZ370247388012QQcmdZViewItemQQimsxZ20090819?IMSfp=TL090819164007r16027
You can't get the in in the wrong section of the cart (which I suspect has happened).
Please note the link is for information only and I neither know nor have used the seller listed. A google search may well provided a list of sellers for you to choose from.
I have used a continuous ink supply on my Epson (have you noticed they appear less on here for problems?) for 3 1/2 years now and my printing costs are minimal compred to useing either after market refills or refilling myself.
