Nokia 6710 Navigator Cell Phone Logo
Anonymous Posted on Nov 27, 2011
Nokia 6710 does not catch the wifi of my home but it shows other wifi network.but other mobile catches the network of wifi of home.
Nokia 6710 does not catch or nor scan a wifi network of my home but when i search or scan from other mobile it shows the network of wifi.but my mobile 6710 scan other wifi network only not of home network.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
243
Points
Your Nokia phone will see 802.11 b/g signals. Is your home access point broadcasting one of these?
I need unlock codes for nokia 6710s navigator
Hi it means your Nokia 6710 navigator mobile is locked to one network provider due to this it wont accept other network sim in it .When you insert other network sim it ask for code to unlock your mobile .To purchase code visit Wickedunlock.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
3helpful
Network is not catching ........ and it tells no network found. wen v search for a network
i need to tri sim mobile(Lephone) network is not catching ........ and it tells no network found. wen v search for a network please rectfy my problem
3helpful
2answers
Network problem
hey hi buddy...
this is not a big work,just switch off phone and take sim card out and re insert your sim again to the phone ...sometimes it happens due to network problem also..even after trying this if it does not catch the network,then go to settings,phone settings,network settings and change the network selection mode to manual an d see that the network you are using is being displayed or not????if it does not catches any network then the fault i with the phone,or if it catches other network and only the network which you use is not being displayed,then the problem is with the network.......
of fault lies with phone you can update or re install the software from nokia care....
thank you........good day
1helpful
Need help for unlocking 6710 Navigator
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan be got from your old service provider..This restriction code iskeptto prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
NO NETWORK
HI,
YOU GOTTA CHECK YOUR SIM CARD 1ST.AND ALSO THE LOCATION WHERE YOU ARE,TO MAKE SURE THAT NETWORK SIGNALS ARE COMING, CHECK ANY OTHERS CELL OF SAME NETWORK.IF YOU HAVE ANY OTHER NETWORK'S SIM.CHECK IS IT CATCHING SIGNALS ! IF THE PROBLEM PERSIST THEN YOU SHOULD GO TO MOBILE ENGINEER.(CUZ IT WILL BE YOUR MOBILE'S NETWORK SIGNAL IC'S FAULT).
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
