Sony Playstation 3 (PS3) Console Logo
marilee Posted on Nov 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the fuse in a ps3 - Sony Playstation 3 (PS3) Console
shaun taylor
Level 3:
  • Sony Master 1,527 Answers
  • Posted on Nov 27, 2011
shaun taylor
Sony Master
Level 3:
Answers
1527
Questions
0
Helped
338040
Points
3957
Hi, there is a glass type fuse in the power supply of the ps3 also there usually soldered in fuses called wickman fuses hope it helps
regards
shaun
1helpful
Will not switch on
hello, have you checked the glass fuse inside the ps3 it will been in the power supply , you will need a multimeter to test the fuse beware if you replace the fuse and it blows again then there a dead short someware i' e a bad component good luck
regards
shaun
Playstation 3 will not turn on
hello have you check the fuse in the black lead if ok then check the fuse in side the ps3 there might be a glass type fuse or a soldered in type called a wickman good luck
regards
shaun
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
1helpful
Ps3 blows fuse at plug
Cocodinaro,
It sounds like you're using a damaged power strip; however, this issue can be caused by a bad outlet.
Replace the fuse and plug the unit into a different outlet. If the fuse blows, you need to go to a video game store an purchase a new power strip.
Regards,
Reddwolf25
PS3 Nothing..No Power Light.. Nothing
Hi there, by the sounds of it you could have faulty fuses, Whether its inside the console itself or inside the Power adaptor its Uncertain. Before opening up Your PS3 i would suggest Checking the fuse in the power adaptor to make sure that is not fried. if it isnt. then it must be something to do with the power input to your PS3 Device. it could be either the Fuse or The transistors on the Power input Circuit. When you Pop open your PS3, Go straight to the back-end where the power input is located, and see if any of the fuses or transistors look fried, if they are. then that is where your fault lies !
1helpful
4answers
Ps3 no power
PS3 unit has fuses that probably failed. I wouldn't void the warrenty to try and change them yourself but this would be the place to start if you take it in for repair.
Does not come on
Try the fuse box in your house first then check if your plug is working (on the wall). If its broken you'll have to send it to Sony.
5answers
No power on PS3
I THINK YOU NEED TO BUY NEW RCA JACKS,, BECAUSE IF THE ELECTRICAL FUSE WENT FROMT HE TV TO RCA JACKS THEN ALL THE CORDS THAT PLUGS TO THE PS2 ARE SHORTED OUT.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
