Question about Fisher and Paykel Aquasmart wl80t65c
Error codes 49 and 245
Hi, I get error code 49 on wash cycles and error code 245 on spin and spin and rince cycles. All the water solenoids have a resistance of 58 ohms. I have cleaned the pump motor and measured the resistance between red, blue and white to be 17 ohms. Any ideas, befor I change the motor controller?
    New Friend:
  • 88 Answers
Fault code 49 is water valves - usually, the stop working when the rubber diaphagm inside gets hard, so a resistance only test is not conclusive (only tells us the solenoid is OK).
- Do a cold fill and a hot fill (briefly) to check for strong water flow on both.
- Regarding code 245, does water pump out strongly?
- One more thought, because these codes are both related to the water level in the machine, remove the level sensor hose at the controller end and blow into it to clear any blockage.
Posted on Jan 31, 2018
SOURCE:
  • 51 Answers
SOURCE: Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Posted on Jul 24, 2007
SOURCE: error code 37!!!!!!!!!
I had the same problem. The machine was not draining. I drained the water tipped the machine on its face and exposed the pump. As you face the bottom of the pump there is a plastic lever on the left hand side of the pump. Depress the lever and turn the pump assembly counter clocwise to remove. In my machine I found a piece of a toothpick and a bit of cellophane. Enough to stop the pump impellor. Aside from draining the water it took me an hour to figure this out. Next time it will be 5 minutes!
Good Luck
Posted on Jan 28, 2008
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Posted on Oct 21, 2008
SOURCE: Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
stephanos18
  • 144 Answers
SOURCE: Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Posted on Mar 24, 2009
Fisher Paykel washer won't spin and drain. Any solution? Error looks like no E AP
possible answer for you see the link after reading Error/Fault code 00000101. (The value is 5.) It wasnt draining the water out at the rince cycle. I saw comments on fixya.com that others with the same problem found clothing between the outer bowel & the inner bowel or an item such as a necklace chain or hairclip jamming up the propeller..... (Two days later, see part 2....) I just fixed this F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.) Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!! Fisher Paykel GW612 Not rincing spinning part 1
Mar 15, 2018 | Fisher Washing Machines
Halfway into wash cycle fe code appears, we can select drain & spin cycle and it will finish. how do we fix
The FE error code indicates an Over Flow Error. The machine thinks that the water level is too high in the tub.
There could be three causes to this problem.
1. The water level sensor is bad.
2. One of the solenoids is bad, either hot or cold.
3. The main circuit board is bad.
Mar 07, 2015 | LG Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
My wjre55502kww ge washer will not fill.
You will need to replace the water inlet valve. Here is the part you need.
Oct 15, 2012 | Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Feb 18, 2008 | LG WM2688H Front Load Washer
Fisher and Paykel Aquasmart wl80t65c Logo
164 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
