Onkyo TX-SR876 Receiver Logo
Valentine Morgan Posted on Nov 27, 2011
Sceen on tv freezes - Onkyo TX-SR876 Receiver
Anonymous
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 27 Answers
  • Posted on Nov 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Teacher:
Answers
27
Questions
0
Helped
20462
Points
44
Open the cover and place a fan on top of the HDMI board. most likely this will be the cause since most issues with onkyo are related to heating.
this should do it.or try to reset the HDMI Board, HOLD BD/DVD button and press power bottom it will give you an option to disabe the HDMI card. it that does not work contact me I can give you the steps to run the ONKYO diagnostics it's conbination of keys that will give you about 50 diferents tests to perform.
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
3answers
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
Looking for manual TV flat sceen LE 32 PVR 0801
yes found a manual go one from an e/bay member who has the same tv.
you could not help.
thanks
Brian
My Sanyo TV sceen goes Wiggy
Ur convergence is dead.U need ICS and a resistor needed to replace.U know how to solders?Go to this website TV Repair World.com.Ur tv model buy a convergence kid.Follow the directions,do the work.
When playing games on my PS3 the screen will occasionally start to jump, or the game will freeze. This happens mostly when I play NBA Live 09. The game loads fine then the sceen jumps constantly.
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up.. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up.
2helpful
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Lcd shadow
you need to call acer you have a bad lcd sceen. i juct di one the sceen was fault.
BLACKBOX AT THE BOTTOM OF SCEEN
A text box is what you are seeing.....a function of closed-caption
feature...select CC and change until box goes out..........T.
Seeing green du42px12x
I don't have a solution, but have a similar problem, when sceens change, red and green pixels form and create a burn in effect from the privious sceen. It happens after the TV has been on for at least an hour. I notice it most when goinf from a light to dark sceen. Any help would be great
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
