Peugeot Watches Gate Peugeot 206 Cc Black Car With Workable Roof 118 Logo
Posted on Nov 27, 2011
Fault code c2118 abs fault peugeot 206 - Peugeot Watches Gate Peugeot 206 Cc Black Car With Workable Roof 118
My Peogeot 206 HDI has a diagnostic error code P14660. The engine turns but it doesn't start
that fault code is too high for a Peugeot 206 with OBD2
i checked all the Peugeot car forum sites for answers
on that code
P14660 no mention
PO4660 no mention
PO1466 no mention
need to start back old school diagnosis
fuel pump ... spark at plugs
this is the world list of all PO obd2 fault codes
http://www.troublecodes.net/pcodes
Peugeot 206 error code p14660
on that code
P14660 no mention
PO4660 no mention
PO1466 no mention
My peugeot 206 model doesn't have revs whats the problem?
could be in limp mode
run the fault codes to see what is reported
1helpful
My Peugeot 206 cc is displaying Breaking fault on the dashboard but I have changed both breaking disks and pads. What might be still the problem.
it could be the ABS system, the proportioning valve in the brake system, low fluid in the reservoir.
run the fault codes to find the reason.
Peugeot 206 losing power and regain power again
run the fault codes as it could be a tank venting problem ( canister purge valve ) or blocked cat converter
How to fix error code C1380 ABS pump fault
heya u should just need to change the abs pump.....u might not even need to change it as these faults just happen for no reason other than a dirty sensor..... ur ecu ye you dnt need to change try ur brake pads first start wit the cheapest and work ur way through the brakeing system b4 buying any parts hope it helps
Peugeot 206 XS Can't accelerate above 1000 rpm at any gear
The very first thing you need to do here is have the engine control module scanned for fault codes with an OBD2 fault code reader or scan tool. Once you have the fault codes then you can diagnose the cause by the fault code or codes received.
Hi I have a peugeot 206 02 gti my abs light has come on and it sometimes flashes up and says ABS fault does this mean I need to replace dics and pads?
yes more then likly the pads have a wire on them and when the pads waer down it compleates a circuit and the light comes on pads are easy to do but you will need to wined the plungers back in to fit new pads.
hope this helps
I need the wiring diagram for my 206 ABS
I've uploaded the Harness diagrams of ABS sensors and ABS control unit of 206 for you. Only 30 days to download after the date of this post.
http://www.gigasize.com/get.php?d=br2qhp4h97d
Top Peugeot Watches Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Peugeot Watches Toy Expert? Answer questions, earn points and help others
