PS3 headset "afterglow" blue tooth communicator
SOURCE: I have a H350 Blue tooth, I have a new phone, I forgot passkey.
Pin or pass code should be 0000.
SOURCE: i need the passkey for
Most blue tooth manufactures use a 4 digit pin or pairing code you first must discover your device you have to put the device in discovery mode once you have done all taht and you are asked for the pin or pairing code they are as follows 0000,1234,1111, or 9999 i hope this helps
SOURCE: how do i sync my mad catz blue tooth headset to my
You'll need your controller, console, and headset to do this. Make sure your headset is off before you start, then follow these simple steps.
If any part of this confuses you, you can find the manual for your headset online here. You'll need a PDF reader to view the file. There are plenty of free ones on the web, but if you don't already have one, I'd recommend this one. It's free and simple.
SOURCE: changed phones want to install blue tooth h700 but
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
First off, you want to have the H700 fully charged up and it's probably good
to have the PHONE fully charged up too. Now turn off the H700 (the ring around
the talk button should not be flashing blue every few seconds) then push
the talk button for about five seconds, until the ring around it displays a
purple color. Immediately let go of the button and flip open the tiny
microphone extension. Now it's in pairing mode and you can leave it while you
fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main
tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even
though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for
available units in the bluetooth frequency spectrum and hopefully find your
H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan
another time or two. Also make sure that the H700 is still showing purple, not
blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so
don't stop here. Select the H700 and you'll be asked if you want to bond the
two units:
You want to say "YES", of course, at which point the PHONE will
ask you for the bluetooth passkey of the H700, which, like all Motorola
bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for
it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple
"pairing" mode but has switched to the regular slowly flashing blue
mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
font-size:10.0pt;
Please remember to vote
and
leave a testimonial. Thanks.
should be 0000
