Casio fx-300ES Calculator Logo
shaun Posted on Nov 26, 2011
I am trying 0.037 Amps to milliamperes by useing the x10x button i am preety sure i should press 0.037x10-3 but the answer comes up 37/1000000 when the answer should be 37 not sure if the calculators set up wrong or am pressing the wrong button can some 1 please enlighten me its a casio fx-85gt calculator
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Dec 07, 2011
Anonymous
Contributor
Level 1:
Answers
37
Questions
0
Helped
34282
Points
49
Prefixes such as milli already reflect the corresponding multiplier or divisor. One milliamp is 1/1000th of an Amp, so 37 milliamps = 0.037 of an Amp.
To keep two sides of an equation the same, you need to perform the same operation on each side. In this case, the equation is 37/1000 = 0.037. The "divide by 1000" part of this equation is included in the word "milliamp", hence 37 milliamps = 0.037 Amps.
Another way of looking at it is that a number remains unchanged if you both divide and multiply it by the same number. In this case, changing to milliamps is dividing by 1000, so you need to multiply by 1000 to keep the result unchanged.
You have actually divided by 1000 twice as a result of using x10^-3 as a multiplier when you should have used x10^3
1helpful
000 wd5000c035
Yes, this model is certainly compatible with Windows 7.
If you've lost the AC adapter and need to replace it, the most important things to look at are:
1) the size of the plug
2) the input voltage of the drive
3) the minimum current in Amperes (A) or milliAmperes (mA) required
For units manufactured after June 1st 2008, these are the requirements:
12 Volts
1.5 Amps
18 Watts
Western Digital recommends only using original WD power adapters.
See here for more information: https://wdc.custhelp.com/app/answers/detail/a_id/1378/related/1/session/L2F2LzEvdGltZS8xMzg3MTQwNTQxL3NpZC9aNG1NbVZIbA%3D%3D
Tip: sometimes you can find a cheap and original power adapter on eBay or Craigslist or Kijiji.
How do I input a problem using log
What does it give you? What is this 10exp11?
If you want to enter 7.8X10^11 type it as 7.8[EE]11. [EE] is the key [Exp[, or [EE] or [x10X]. The EE is a short cut for *10 to a power. The 10 must not be appear in the expression entered.
I am trying to record my outgoing answering machine message on my Uniden Dect 6.0 cordless phone. I know my security code, but I don't know how to record it.
Hi There,
Press the Menu button Use the volume up/down buttons to navigate to 'Answ. Setup' Press OK Use the volume up/down buttons again to get to 'Record greeting' You might need to press OK here, I'm not sure. Press the Start key and record your greeting
2helpful
I have to multiply by Pi on my exam paper. (I'm wondering where the Pi button is on the Casio Fx-300ES Calculator)?
To insert pi on this calculator press [shift] [x10x] . (you can see the pi symbol above and to the side of this button).
2answers
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
2helpful
I want to use the pi button {x10x} and i dont know how to work it?please help!
Press SHIFT button then the x10^x button to put the value of pi into the display.
4helpful
How do I enter pi on Casio fx-115es?
Enter your number then press (shift) then (X10x) key. That will enter pi. then press (=) for the answer.
4helpful
Trying to use in standard form says to use the exp or ee button which i cant find plss help !!!
Times are achanging. The powers of 10 used to be represented by EXP or even EE. But cheer up, it seems that Casio came to its senses and now they represent it as x10X (multiply by 10 to the Xth power) It is the middle key on the lowest row.
After you press the key, enter the exponent.
Sharp Microwave Oven Corousel
I replied privately to this, stating it may be the HV capacitor, or possibly the magnetron or transformer and giving links.
We're happy to help and we appreciate your thoughtful rating of our answer.
3answers
Casio Classpad 300 plus
I bought a classpad 300 plus but I dont know how to operate it. I saw some books for classpad 300 and I really want to buy some. However everytime I try to buy, there is always a classpad that goes with the books . Can I buy books for classpad with out buying a calculator anymore?
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
