The current video driver seems to freeze after about 4 minutes into a fresh install of Windows XP or Windows 7. I am unable to boot the original Vista image either. I have reformatted the HD several times. I believe I need to upgrade the bios on the lap top. I am not sure how to do that without an OS. Please advise.
Remove the battery of laptop and press power button to discharge any charge in motherboard that will reset the bios. Put battery back and press start button and press hold delete button to enter into bios, where you can select optimized setting or fail save mode whatever good options available and boot. If you have windows 7 installed, check your RAM. For instructions use https://www.youtube.com/watch?v=GJsVvHJqO34
This link helps improve browsing skills.
https://www.youtube.com/watch?v=9C3SRvhUMwY
SOURCE: Toshiba Satellite 5005-S504; boot from USB? Reformat HD w/o CD-ROM?
Are you saying you want to re-install XP on the hard drive? If the 5005 has the same bios as 90% of the Toshibas out there, "usb devices, or usb rom" should be one of the options in the boot order in the bios. It's a bit different tho, in that if you press F12 for temp boot order, it seems as if it doesn't do anything, but in fact, the icons across the lower 1/3 of the screen are your boot options; just move the highlight to the desired icon. Good luck. BTW, what's made these "infamous"?
SOURCE: How to format and install a OS into the HARD DISK using a PEN DRIVE ......
nope..that is a complete compatibility challenge of the first order..
SOURCE: Bluetooth not working after OS re-install on Lenovo 3000 Y500 lap
if you install xp then find out the xp drivers in www.lenovo.com > select country > support and downloads > model number> etc. After downloading file >install the driver > after installation reboot your computer > after machin on you just switch on the wifi or bluetooth switch (near you laptop hinzes) and try it.
SOURCE: how to recover after upgrading to windows7
hey listen if u upgrade ur OS to Win 7 then ur programs will have capabilty tu run in that OS and u'll be able to roll back ur changes after upgrade and One-touch key recovery will help to roll back ur prev version of windows
SOURCE: Hang problem Toshiba satellite a205-s4607
May be your Computer is infected and check for cables.
You need to run your computer through Safe mode with Networking and run the Anti Malware bytes and ccleaner(Run this software and analyze first and then Run Cleaner)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
