I have a 125cc Atomik pit bike I undid what I thought was the oil drain plug and a metal cylinder and a long spring flew out, I just need to know what order and direction these go back in, thanks.
After hunting around the web for a few, it sounds like the spring is from the timing chain tensioner. It looks like there is a button on the end of the cylinder, that end goes in first, then the spring. See if the spring is the same on both ends, the picture looks like it's smaller at one end and that end goes into the tensioner, not the bolt. I'll include a screen shot of the picture. Good luck!
On the kick start side of ur bike on the carb the should be a bolt on the carb ball loosen it off till all the water and fuel comes out. If ur bike still want run u need to take the carb off and clean all the jets.
Underneath is the usual location for sump plug. Otherwise sitting on the bike the oil drain plug should be on your left side underneath the front sprocket somewhere....
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
