Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
Anonymous Posted on Aug 08, 2017
Cannot load windows XP
My laptop just restart ad didn't load anymore. There is a black screen saying that there might be a hardware or software that may have caused the problem. i tried to Diagnose using F12 but there is no partition found. I don't have my dell drivers and utilities anymore so I don't know what to do.. Windows is not starting normally even in the safe mode. Please help me. Thanks in advance.
Bill Boyd
Level 3:
Top Expert:
  • Dell Master 53,816 Answers
  • Posted on Aug 08, 2017
Bill Boyd
Dell Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925760
Points
172802
Indicates that it is a failed hard drive
if that is the case ensure that the replacement is a solid state hard drive
and get and load win 7 as win xp is no longer supported by microsoft
4 Related Answers
Anonymous
  • 2785 Answers
  • Posted on Dec 23, 2008
SOURCE: Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Anonymous
  • 33 Answers
  • Posted on Jan 14, 2009
SOURCE: USB Hardware Installation Problem
Basially, what i learn from your problem that any removable media is not detected by your Dell laptop. You have tried all the things, now, just make one more try.
In my opinion, your windows are corrupt, hence they are not detecting any type of media. Please try to find the Windows XP setup CD ( Which may be there in your laptop kit when bought). If you have installed windows from pirated CD, get that one. Any CD will help.
Do it like this :
1. First un-install all the antivirus antispy and antimalware programs from your machine.
2. Put your winXP CD in CD rom drive and start the laptop. If WinXP setup starts, no issues. If not, then leave the CD there only and restart the machine. Then, go into setup by hitting delete key ( or the key which is shown as the first screen when laptop starts) when the first screen appears.
3. When you enter setup, select advanced settings and go to "boot device priority"
4. select first boot device as CD rom, save the changes and exit.
5. now the CD will your machine. when asked for, select you want to install winXP. After that option, the Setup will detect your existing version of installation, i.e. C:\windows. At this point of time, select R to repair the windows.
6. IMP : Dont select repair at the first option, it will not help. I repeat, first select you want to install XP. Thereafter select R at the next option.
7. Now windows will repair the current setup of windows. Please keep Windows CD ready with you and insert it when asked for.
8. After setup, the machine will start as normal one, and detect all the hardware including USB media etc.
Anonymous
  • 52 Answers
  • Posted on Jun 10, 2009
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Anonymous
  • 69 Answers
  • Posted on Feb 06, 2011
SOURCE: I had Dell Windows XP
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Black screen then blue screen with cursor
Unfortunately after trying to restore to earlier point and didn't succeed ,u have to reinstall a fresh copy of windows. Before you do that ,check whether you have added any new hardware or USB drive/mouse/webcam or keyboard and restart.
Dell inspiron mini 10 Turn it on, put in password. screen says windows did not start up sucessfully. A recent hardware or software change may have caused this. then i go to the last known good...
A blue screen with white writing appears on my computer,
just before windows is about to begin and it reads:
A problem has been detected and windows has been shut
down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've seen this stop error
screen restart you're computer.
If this screen appears again follow these steps:
Check to make sure any new hardware or software is
properly installed. If this is a new installation, ask
your hardware/software manufacturer for any windows
updates you might need.
If problems continue, disable or remove any newly
installed hardware/software. Disable BIOS memory options
such as caching or shadowing. If you need to use safe
mode to remove or disable components, restart your
computer, press F8 to select advanced startup options,
and then select safe mode.
Technical information:
STOP: 0XOOOOOOED
(OX8OED4AF8, OXCOOOOO32, OXOOOOOOOO,OXOOOOOOOO)
I cannot go into windows even in safe mode, and I don't
know how to execute any of the other things it's telling
me to do.
It may have something to do with my virtual memory as
windows had to increase it while I was playing a computer
game, or because I added some extra pictures I downloaded
to a computer game folder where the default pictures were
already stored.
if u cant do these then reinstall the operating system.
3answers
When Power On, the computer appears to be starting, get DELL logo, then black screen, then "We apologize for the inconvenience. Windows did not start successfully. A recent hardware change or...
Hi
You didn't told us, what is the most recent updates you've done, i.e.: installing driver or software, or something like this.
Choose 'Last Known Good Configuration', if not worked, choose 'safe mode'
Please tell us your results
Good Luck
1helpful
2answers
When the computer boots, the loading Progress Bar of Windows XP is displayed, but as soon as the computer goes into Windows XP, the screen turns black and stays black.
Welcome to FixYa
Dear user
This might be Hardware or Software Issue.If you have installed any New Hardware of Software Simply Remove it .And Try to Boot.In case of Software,Try to boot in SAFE-MODE by pressing 'F8KEY' when booting time to Enter SAFE Mode...After Entering Safe mode You can Uninstall newly installed Softwares.It might be reason for Clash in windows system Boot file.
Let me know if you need Further assistance...Hope this Helps...Thanks for Connecting FixYa,,,
4helpful
3answers
Inspiron 1525 Error Code 4600:021E msg: Processor
There are several Reasons.
  1. Your Processor heated up more than the expected limit. Often caused by a trouble with Heat-Sink(and or the Copper tunnel if have one inside), Short Circuit. You have to check the Processor and its Socket.
  2. CPU fan is not functioning: You have to check whether the fan works properly (with a good speed - rpm).
  3. Your Sensor has a fault. You have to check the Sensor.
WHEN I TURN MY WINDOWS XP ON IT HAS A BLACK SCREEN WITH WHITE WRITING SAYING, WE APPOLOGIZE FOE THIS INCONVENIENCE, , BUT WINDOWS DID NOT START SUCCESSFULLY. A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT...
Try safe mode.
If that works, there is a card or software that has failed.
Checking the cards is easy, take them out one at a time and restart, for motherboard features, shut them down one at a time.
For software, did you load anything new, even updates, if so remove them.
Mine turned out to be a bad PCI card for a scanner.
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Start up problem that will not allow windows program run restarts
send me the error that comes out when you start your laptop so that we can analyze that problem. [email protected]
SONY VAIO PCG-7G1M Wont boot
First you understand yourself is that after the windows logo screen apperars and its get restart means there is some changes or malfunction happened to your hardware - Although you changed your hard disk will not solve your problem. Please clarify as follows
1) did you load you operating system to this hard disk by any other computer help - if you load it with the same system try to reinstall the system.
If the problem existing 100% your motherboard is partially damage I think the uniprocessor side voltage variation is happening while you press keyboard some charge (voltage) you are supplying to the motherboard, sometimes some key pulse is more than 5 volt so that pulse support to get moved some points
First check your windows try to reinstall agian - I predict that you got this hard disk installed through some other laptop so the hardware configuration is different.
Thanks Hothawk
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
