We have two CVC6993R cameras connected to pc (vista). We can see pictures very clearly but are struggling with recording. We are trying to record on motion. Somtimes the R comes on the corner of the screen which we think means that it's recording if it is we are unable to access it. I hope you can help.
SOURCE: Camera and Video Recorder will not work on MOTOKRZR K1
Hi i tried having the live chat but it wouldnt let me the problem you are having is a software problem this needs reseting and the software reinstalling this isnt something you can do yourself but can only be done at repair shop it wont cost to much but this is the only way you can fix this problem ok let me know if you need further assistance ok
SOURCE: Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
SOURCE: playback static
Your video heads are probably dirty. I have the same problem with mine too. If you buy a 8mm video cassette cleaner, it should work. Unless there is some other problem.
SOURCE: record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
SOURCE: My New Panasonic RR-US470 digital
What you need to do is unistall the driver for the device and reinstall it using the CD.
1. With the device connected go to the control panel
2. Search "driver" in the search box at the top right hand side of the screen
3. Choose the "device manager" option. If a pop up appears just choose continue.
4. At the bottom of the list open the menu for the "Universal Serial Bus Controllors" if it is not already open.
5. Double click on the "Panasonic IC Recorder" choice to open a new menu
6. Click on the "driver" tab
7. At the bottom of the list is the "uninstall driver (Advanced)" button, click it
8. After the driver is uninstalled disconnect the device from the PC
9. Reconnect the device, and it will bring up a new pop up. Choose the "Install Driver" option, it should be the first
10. It will then ask you to insert the CD that came with the device, just insert disc 1 in to the CD tray
Vista takes over from there and installs the driver for you and now your device will show the PC on the screen.
Hope that helps, I know it worked for me
