SOURCE: Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
SOURCE: Printer Error Code 20 HP Deskjet
Dear rowanleigh,
What u have to do is just unistall the printer Driver restart the system then Reinstall the printer driver. and also do one thing delet all the temp files, temporary internet files & run the Disk cleanup tool.
Regards,
Bittu_8
SOURCE: I don't know how to find printer documentation on Error Oxc18a0101.
You need to reset the printer. Please follow the instructions in this link, and if that doesn't work, try this link.
If neither is successful, you may have to have the unit serviced, but usually one or the other method will get your printer back online.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: cartridge error
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd9
