GE Profile JP930 Electric Cooktop Logo
Eric Posted on Nov 25, 2011
GE Proflile JGP975 Gas Cooktop Lock issues
Control Lock failure
5 Related Answers
Anonymous
  • 106 Answers
  • Posted on Nov 22, 2009
SOURCE: Burner control will not depress or turn. This is a
constantly cleaning with spray cleaner or too much water may have leaked down into the steam of the valve and rusted it. replace the valve and lycon switch
Anonymous
  • 110 Answers
  • Posted on Apr 12, 2010
SOURCE: A technician replaced the ignitor module and
one of the switches is still stuck on ignite try to isolate which one it is most likley there is still liquid causeing it to stick ie grease something stickey check the valve that sends gas back to the rear burners again it sounds like not all of the liquid has been removed look closley and always be safe
Anonymous
  • 43501 Answers
  • Posted on Aug 19, 2010
SOURCE: the flame does not come on JGP975 gas cooktop. we had a spill.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Anonymous
  • 43501 Answers
  • Posted on Aug 30, 2010
SOURCE: 30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Anonymous
  • 43501 Answers
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
2answers
Fuse location on GE Profile PP975S Cooktop (If there is one)?
Question edited for clarity.
There is no fuse, the loads are too great.
The Service Manual is in the link. Check the Control Lock on Page 11.
https://ja.safe-manuals.com/source/pdf/adea1af72b5b020af66562d603ff2631
https://www.google.com/search?q=ge+pp975s+fuse+location
Dec 24, 2022 • GE Cooktops
1helpful
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
1helpful
GE gas cooktop modelJGP970BEK2BB. The unit is in the unlocked position, burners will light, but "lock" light remains on and buzzer/alarm sounds the whole time?
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
3helpful
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
The flame does not come on JGP975 gas cooktop. we had a spill.
heatman101
1helpful
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
4helpful
Ticking sound from GE cooktop igniter
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
