Perhaps you check the settings. If the camera is on nightshot, or manual, with a long shutter time or wilde open diafragma your pictures are all overblown, or stripes come from lights. Put the camera in automatic. The main dial on the green camera logo, and try again. If this does not work, Please let me know how the settings are on your camera. Success
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I had this problem too, I think it's the shutter problem, it doesn't close when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
