I can't access and format my flash disk
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
SOURCE: PNY 4 G USB DISK IS WRITE PROTECTED
Not sure what exactly is happening when you try to use the disk. Is it a used disk? Did you just purchase it? Do you get an error when trying to use it?
From the limited information, I would suggest going to the website and seeing if there is a solution from PNY: http://www2.pny.com/support/support_landing_cat.aspx?SectionID=1143 (their support page).
If it still doesn't work, post more details & I'll see if I can help.
Have a good day!
SOURCE: Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
SOURCE: Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
