I had the same issue - I found that there is a square chip, about an inch and a half from the amplifier chips and heat sink, which got so hot (i could not even touch it), it was seperating one of its pins from the circuit board (due to a hairline crack on the pin itself. When it got that hot, ther metal pin seperated at the crack which made this chip short out, creating the "protect" to happen. I resoldered the solder joints on the circuit board where the pins of this chip connected and fixed the cracked pin with a jumper strand of wire, then made an aluminum heat sink and connected it directly to the chip -no more issues!
SOURCE: Blinking Protect Mode
Hi all i have the same receiver from sony so my story is
When i turn my receiver on and one off the 4 relay's dont turn on, and the same time on the display is showing
a flashing message " PROTECT" a have tried many times to hok up another speakers of many impendances but nothing no short circuit on the output and then i decided to open my amp after few hours i find a problem finaly one off the integrated circuits near the out put transistors the ic was a
upc2581v (fet driver) and the problem was a bad soldering can you belive this ? i have soldered the ic again and cut off the long legs from the ic and put together the amp and is WORK'S and the amp is made in france i thing you chek this ic in your amp's becuse the soldering off the board is very bad. hi all
SOURCE: protection mode
I have also experienced the AVR-37600 unit went into protection mode after whole day testing and found one of the channel defective.
Please check all the connectors are proper intact with the cards
