Question about Homelite Mighty Lite Lawn Trimmer
26CC HOMELITE MIGHTY LITE LAWN TRIMMER PROBLEMS
ALOHA, I HAVE A 26CC MIGHTY LITE WEED WHACKER. I GOT IT USED AND IT LOOKS FAIRLY NEW. THE PREVIOUS OWNER SAID IT WILL ONLY RUN WITH THE CHOKE ON. I HAVE FOLLOWED THE STARTING INSTRUCTIONS AND IT WILL START RIGHT UP, BUT WHEN I TRY TO ADJUST THE CHOKE SETTINGS IT BOGS DOWN AND SHUTS OFF, TRIED PUMPING THE TROTTLE BUT IT ONLYS BOGS DOWN. NOW I TRIED LEAVING THE CHOKE ADJUSTMENT ON AND IT WILL STAY RUNNING AND REV UP, BUT NOT REALLY LIKE IT SHOULD. I CANNOT FIGURE IT OUT! PLEASE HELP! THANKYOU!
  • 3 more comments
  • nickoftime Oct 03, 2008
    will start but wont idle or rev
  • Anonymous Oct 11, 2008
    Same problem with my Homelite trimmer. Will start o.k. on full choke but once I switch to "run" it bogs down & turns off.
  • racing1055 Oct 13, 2008
    I have a Homelite 26vt. I bought it new and after the first tank of gas it started with the same problem you are describing, runs only with full coke and stalls once you open it. I tried cleaning the carb twice but it does'nt get better. Someone knows were can I find a parts diagram of the carb to find out if something is missing?
  • Anonymous Apr 08, 2009
    I have the same problem with my trimmer. It worked great for 2 years but now bogs down when you take the choke of and push the throttle. I took the whole engine apart, cleaned the carburetor, put fresh gas in it, etc. I might try replacing the little filter inside the gas tank. I even checked the muffler and made sure it was not clogged and air could still get through. I e-mailed homelite and they told me that if the troubleshooting in the manuel doesn't correct the problem to take it to a non existent repair facility in my area. I am thinking it's time for a new trimmer!
  • Anonymous Apr 26, 2009
    I have the same problem with my Homelite leaf blower. I think I need to adjust the jets.
    New Friend:
Had same problem with my reconditioned unit. After a few hours engine would run only with 1/2 choke and full throttle. Like most 2 cycle engines, the unit was starving for gas.
Solution: Adjust both carburetor screws. These screws are located directly below the idle adjustment screw. There are 2 of them side-by-side and they are approx. 3/16 diameter with an oval shaped cast metal raised restricter. Simply remove the plastic round air filter by removing the small nut. Then, using a Dremel tool while wearing safety glasses, cut a slot in the face of each screw. Cutting through the raised cast metal surrounding the screws will not damage the unit. Then using a small flat blade screwdriver, screw each screw clockwise till it stops then back-out each screw 2 turns. Factory setting is 1 - 1/2 turn each. However, the unit over time runs too lean with the factory setting.
Then start unit, let warm up with 1/2 choke, then turn to run position and make any final adjustments.
Making this adjustment, I am once agin able to trim my yard in the idle position. Runs Great !!!! Hope this helps.
Posted on Nov 12, 2009
  • 1 more comment
  • vr6isfaster May 20, 2011
    I wound up doing this to my 26cc mightylite (mighty lite) blower with great results. Had the same too-lean factory setting problem. I was afraid of cutting too deeply and causing a leak, but that was not an issue. Just make sure you have a small thin flathead to tune with and you won't have to molest the machine too much. Typical dremel wheels make a very thin slot. And as above, foresight is better than no sight (wear the flippin' safety goggles with the dremel!) Thanks above for being the first to risk their unit and discover this easy fix. -Alex Fink
  • lynchbrt Jul 23, 2011
    The two screw thing WORKS great. Thanks people!!!!!
  • Shane Robinson
    Shane Robinson Mar 18, 2014
    Just ran into this problem on my Mightylite. This was the fix I was after, cost free if you own hacksaw blade and a flathead srew driver. Works great and it's now adjustable any time I run into a problem. Only had to remove the plastic cover on the side (clips off) and then used small cuts and pulled the starter switch cord out of the way. Was worried about cutting into the machine, but it was totally harmless, my need to fix it outweighed my fear of damage. Thanks a lot for this simple, cost free (or low cost) fix.
    New Friend:
You will probably find that the carburetor on this unit has a "pac man" bit specific to homelite. I have a 2007 model and found the carburetor to be out of adjustment out of the box. Unfortunately, the EPA passed a stupid law that forces the manufacturer to make the carb tamperproof "read un-adjustable by the user" by making the manufacturer use a tamper proof screw unique to homelite. Apparently this stops Americans from killing thousands of whales by adjusting their own carburetors. You have to spend $20 on a "pac man" tool on ebay to adjust it, or take it to a service center and pay for the simple service. You might be able to sneak small needle nose pliers into the fitting to do it, but you will probably scratch up your tool. This is just one of the latest farces of the EPA, who seems to specialize in creating consumer inconveniencing, American commerce damaging (in the national scope due to unnecessary costs), and simply frivolous laws to perpetuate their own bureaucracy. –Alex Fink
Posted on Nov 06, 2009
  • Michael Crow May 15, 2011
    10 min on internet &15 min in the shop and it runs like a charm--thanks so much, tou ended days of frustration--tks again
    I wound up doing exactly what mikehandyman did and it was an easy tune. Go with the dremel mod -(vr6isfaster)
    New Friend:
I had the same problem, hard starting, bogging down and dying, etc. Disassembled the carburetor and cleaned it, as well as the fuel lines and screen in the fuel tank. Nothing helped.
Then, similar to mikehandyman solution #2 above, I cut a slot through those two non-screwheaded screws with a blade from a hacksaw, including cutting through the raised cast metal oval surrounding them. Then used a flat screwdriver to turn them in all the way, then back out two (2) full turns. Runs perfectly now!
Wear leather gloves and eye protection if you try it. It's not that difficult, just takes a few minutes.
Posted on Mar 03, 2010
  • Bravo242 May 26, 2011
    Worked Perfectly
  • Don Ens Jul 03, 2013
    Can someone tell me if there is an aftermarket carb kit, including needle, welch, to fit the Ruixing carb on the Mighty Lite. Similar diaphragm/gaskets on Zama but the needle is to long. Also, cannot seem to find number stamp on carb anywhere. Anyone know how to ID carb? Found available diaphragm/gasket kit, but no complete rebuild kit.
    New Friend:
Yep, DDMiller 229 nailed it for me. Same problem. Not being equipped with a dremmel or such a tool I found that I had to diamantle the area a little bit to get access to the screws in a manner that I could get a hacksaw in, but whan I slapped it all back together after the two turns backward, the thing roared back into life. It's better than it's ever been. It's just so inane of the manufacturer to put these screws in that can only be adjusted with a special tool only available to the specialists. Bunch of creeps. Anyway, my message to others is to follow DDMiller's advice and don't bother messing with the carburettor. If this doesn't fix your problem then maybe you can start troubleshooting elsewhere, but this was the fix for me. Thanks DDmiller. Cheers!
Posted on Apr 25, 2010
I was about to throw this trimmer away after starting my second season struggling once again with this thing. Slotting the carburator screws and adjusting them was the answer for me also! Works fine now. The internet is a wonderful thing.
Posted on May 16, 2010
    New Friend:
Had the same problem right out of the box. Bought it last fall and it would bog down as soon as you hit the gas. Never got around to returning or fixing it until I needed it this spring. The solution is as stated above. Put slots in the jetting screws, turn in all the way and back out 2 turns.
THANKS for your help.
Posted on May 09, 2010
  • rossperrone Jul 15, 2010
    to namilak63
    the primer bulb is on the top of the carburetor. The plastic cover removes from top to bottom. press on the "button" on the top face of the plastic cover to release. The 2 jetting screws are about 1/2 inch below the choke lever. They are recessed into the housing.
    hope this helps.
    namilak63
    the primer bulb is attached to the top of the carburetor. to remove the plastic cover, push the "button" on the top face of the cover. the jetting screws are about 1/2 inch below the choke lever. They are recessed into the housing. the "screws" do not have slot in them. You need to put slots in them so you can turn them with a screwdriver.
    hope this helps.
Check your fuel mixture, if it is to rich(to much oil mixed in with the gas) it will cause it to bog out. Remove two cycle gas from gas tank and be sure to pump the primer to get excess out. Remix fuel(try 40:1, it's leaner and should solve the problem. If that does not solve it, try checking the muffler, sometimes they have screens on them that can get clogged. Also running the weed eater with to rich of fuel can cause the muffler to be clogged. Always check the spark plug and clean it. If none of these solutions fix the problem, then the carburetor needs cleaning.
Posted on Feb 27, 2009
    New Friend:
Had the same problem with my trimmer as soon as I took it out of the box. Tried slotting the screws and reset the fuel mixture, BINGO runs like a top. Thanks for the tip!!!
Posted on Jun 07, 2010
I have a Homelite 26vt Mighty Lite as well, and I was experiencing a similar problem. The trimmer would no longer rev as high as it used to, and it seemed to smoke more than before. I thought maybe I'd premixed too much oil, or the air filter was clogged, but when I took off the choke dial the air "filter" (really just a wire screen) was perfectly clean. Thankfully the wimpy filter allowed me to see the throttle plate fairly clearly, and I noticed that it would barely move when I gave it full throttle. When I pulled the trigger, it would use up about 3/4 of its range of motion just pulling slack out of the throttle cable, and then would only rotate the throttle for the last 1/4 of the way. I took apart the black plastic housing that contains the trigger mechanism and found that the end of the cable jacket was supposed to be held in place by being smashed between the two housing halves, but the plastic had developed enough flex that it had lost its grip on the jacket and was allowing it to move. It seems like a poor design, and possibly a common point of failure. If this is your problem, you should be able to test it by squeezing the trigger all the way (with your trimmer running), then pulling on the bare metal part of the throttle cable to see if you can rev it higher. I put the end of the cable jacket back where it should be and spread some hot glue around the place where it enters the trigger housing, but there's probably a better way to keep it in place. Hopefully there's nothing actually wrong with your engine... good luck!
Posted on Jul 15, 2009
    New Friend:
Here's to DDMiller 229!
I used my Dremel to cut grooves in the two screws, no problema. Now works like a champ, after a lot of previous non-use, blood sweat and tears. Makes you hate govt bureacracy for sure. Also homelite and the chinamen who work for homelite and missed the proper setup.
Many thanks to DDMiller and Fix Ya. I'll bookmark this site!!
Rick McQuiston, Santa Rosa Beach, FL.
Posted on May 11, 2010
    New Friend:
All posters are correct about cutting your own slots. i have 2 homelite models (weedeater/blower) with same engine, i bought at pawn store for 35/ea. they look brand new but run like ****. called my local dealer and asked him for the special tool because i didnt want to hack saw like others (but can do it) becasue didnt want to waste my time. he wouldnt sell the special tool to me! loser! i would have given him $10 if he asked! so i did like other member ans disassembled down to the balck plastic air cover...this allows the carb to come away from engine so it can be moved around a bit for hacksawing angles. it is STILL attached to motor via gas lines. cover all engine/carb ports with cloths, then hack saw completely across the aluminum bridge on the carb, that is ABOVE the mixture screws. saw all the way thru this bridge, and then the screwws themselves. check cut in the screws, you dont need too much. stop when done. reassemble. screw both down then back out 2 turns as mentioned. engine starts no problem. now, adjust each (low and high speeds) run it full. wait till it's hot. adjust it to LEAN side of rich. now adjust idle. adjust idle to RICH side of lean. this gives you good idle and full speeds, but also goo MIDRANGE runup. good luck.
Posted on Apr 12, 2011
    New Friend:
Whatistheredandwhiteplasticnobsoncarb.
Posted on May 24, 2011
    New Friend:
Im so happy! i used the advice on this page and my mightylite 26vt is running. i still have to do some adjustments, but now i can. i also used an hacksaw to cut slots in the adjustment screws. my initial thought was that i didnt want to cut the oval casing around the screws. then i thought, it doesnt run anyway, whats the worst that can happen. i used needle nosed plyers to back the screws out of the casing, but that took too much time and patience. plus it is not precise enough to properly adjust them. then the metal in the screws was too hard to get the saw set. so i screwed them back in and used a hacksaw to cut slots in them. the casing helps get the blade set. i screwed both screws all the way in then backed them both out a little over 1 and 1/2 turns. i cranked it on the first pull and ran great. thanks to everyone who contributed.
Posted on Aug 14, 2010
  • chryar28 Aug 15, 2010
    namilak63 remove the wax nut from the choke wheel. remove the wheel. then remove the center threaded post with the nut on it. youll need a t-25(i think) torx(or star) bit to remove the other screw. remove that plastic housing and youll see the carbeurator.
    New Friend:
Thank goodness for this website and others like it that save homeowners time and money. I slotted the jet screws on my homelite 26cc, adjusted as recommended above, and resurrected this less than two year old unit. If this didn't work I was going to put in the trash tonight and go buy a battery unit. For those that are not aware, the carb and any tuneup adjustments are NOT covered under Homelite's warranty. IMHO, the warranty is useless, as this is the heart of the machine, and is what causes most problems.
Thanks, again, for your willingness to help out those of us who get frustrated when this stuff stops working.
Joe in Ohio
Posted on Jun 16, 2010
    Problem Solver:
Have a 31cc craftsman grass trimmer with 2 lines coming from the gas tank.One goes to a primer bulb then to the carb and the other has a screw in it and does nothing. Does anyone know why its there.
Posted on Jun 21, 2010
Looks like a dirty carbureter. Get the carb. cleaned out or do it yourself. It should be fine.
Posted on Oct 10, 2008
    New Friend:
Same symptoms with my 25cc Homelite HLT25CSS Trimmer. Drove the 'pacman" screw out with a tiny drift and hammer, slotted head by holding screw in a pair of pliers and using a mini hacksaw. Screwed back in and backed out 2 turns, same problem.
Added 1/2 tank of 50:1 premix (rather than the recommended 25:1) and removed the idle screw again and blew carb cleaner into the orifice, also opened the throttle with the air cleaner removed and blew carb cleaner into the carb opening, opened throttle several times and hear a hissing noise from the carb? (Engine was cold at the time), adjusted idle set screw to 1& 1/2 turns from fully closed. The result of these many changes is that the trimmer is running like new, at 1& 1/2 turns out from closed on the idle screw. Either gummed up main jet or too rich premix is my suspicion, but with the several changes made at the same time, I canno be positive. I also put some "Mechanic in a Bottle" in the gas tank last time I used it, but didn't seem to make any difference.
Posted on Sep 17, 2018
    New Friend:
All this advice is great, but, i dont even know how to get to the carb, can somebody describe it for me, please, should i strip the whole plastic housing from it? thnx for any help.
Posted on Jul 12, 2010
4 Suggested Answers
SOURCE:
panilling9
  • 284 Answers
SOURCE: Problems with my HomeLite UT20760 bogs down, no power
try this
you need to locate your muffler and find screws that remove a screen behind a plate you can remove on the muffler or behind the muffler itself
This screen is a spark arrestor screen and needs to be cleaned and put back or some would say discard all together, but i didnt say that.
give it a look see
this may be your problem and maybe not?
if it was you will see a trmendous difference afterwards
Posted on May 31, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
goldenglove1
  • 144 Answers
SOURCE: Replace a primer bulb on a Homelite Mighty Lite
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Posted on Aug 12, 2010
Homelite 26cc hk18
Don cenrtal spares should have them. check the web site
Sep 01, 2013 | Homelite Mighty Lite Lawn Trimmer
How to remove the string holder on a homelite mighty 26cc
Here is a manual similar to your owners manual. See pages (13 and 14 ) inside for instructions on this procedure.
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
Jul 02, 2011 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
22,361 people viewed this question
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
