Question about Craftsman 22" Gas Hedge Trimmer
Hedge trimmer , mod.040090D 40350. Won,t start.. I pulled the plug, grounded the plug body, a spark should be seen at the plug gap., but instead a spark is seen from the plug body to ground, what would cause this
    Guru:
  • 479 Answers
You will see a spark jump from the plug body to ground if it isn't tightly grounded to the engine. However a spark should also jump the gap in the plug at the same time. It can be difficult to check a plug this way because it tends to bounce around the place when pull starting the engine. You could try getting a bit of wire and clipping on end to the exhaust or fin on the engine with a crocodile clip, clothes peg or vice grips. The other end of the wire could be wrapped around the threads of the plug and held with a clip.
Fore more tips on starting a hedge trimmer see:
http://fixofile.host56.com/tips2.html#tip2
Posted on Nov 24, 2011
  • 1 more comment
  • norm sparby Nov 24, 2011
    I have done all of that.. I have tried Quick Start and still
    no start or even a fire
  • EugenesDIYDen
    EugenesDIYDen Nov 25, 2011
    Try replacing the plug.
    Also, if the fuel lines becomes air locked, it can be difficult to start the engine.
    Yo will need to continuously alternate between priming the engine and trying to pull start it.
    Check the vent which lets air into the tank isn't blocked.
  • norm sparby Nov 26, 2011
    I have replaced the plug.. If there is spark, it should start after squirting Quick Start in the cylinder..
SOURCE:
Spear and jackson petrol hedge trimmer, used only twice, now it won't start, have changed the spark plug , not sure what to do now
You need to make sure you have spark. Remove plug, connect spark plug wire, hold plug to motor to make ground. Pull recoil and take note if you have a blue spark on the electrode of the spark plug. If you do, then it is a fuel issue, most likely gummed up the carb. Try carb cleaner spray and fresh gas.
Aug 25, 2011 | Garden
Hello, I have a craftsman gas hedge trimmer that will not start. What are some things I could checl out to try to get it working
Two items fairly easy to check; the condition of the spark plug and whether the ignition coil is healthy. The plug must be removed to check it for fouling (a buildup of deposits near the spark gap) and also wipe the insulator of the plug clean and inspect it carefully for fine lines; a cracked insulator (not uncommon) will provide a path for the spark voltage to ground before it reaches the spark gap. The ignition coil can be checked by sight in a shady area (sunlight makes it tough to see). Pull the plug wire free of the plug and insert anything metallic into the female connector that will extend the contact. Position your extension near some metal part of the engine and watch this gap as you tug on the starter rope. You should be able to see the spark appear a couple of times with each pull of the rope to its limit.
These coils are not very well made and cost $30-40 US to replace.
Once you have access to the coil. use some gauge (could be a knife or screw driver blade) so you can re-gap the coil if a new one is installed.
I suggest that you go to the Sears website below and enter your model number. You should find it listed there and it will have a parts breakdown of your trimmer along with part numbers, etc.:
Sears parts dept.
Using this you can orient yourself on the innards of the trimmer.
May 31, 2011 | Craftsman 22 in Hedge Trimmer
Not getting spark because i loosened the adgustment screws
GAP ON THE COIL ? USE A MATCH BOOK COVER. SPARK PLUG FOLD THE MATCH BOOK
May 25, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Homelite trimmer zr40502
Do you have fresh gas? If so is the mix right? If you can get to the carb easy spray some carb and choke cleaner in it. Check the gap on the new spark plug. The gap should be located somewhere in the manual. The big problem is making sure that the mix is right. To much oil in gas will foul plug smoke like crazy and foul the plug and hard to start. Not enough oil and you can seize it up.
Good luck let me know if this helps.
roundo4
Aug 16, 2009 | Homelite ZR40502 Factory-Reconditioned...
How can I determine if my husqvarna magneto is working?
Remove spark plug from the engine, reconnect it to the plug cap cable which come from the bobin.
Find a piece of steel wire jumper, atleast a foot. Make a jump from the metal body of the plug to the chassis of the engine.
Safety issue: Place the plug away from the spark plug's hole on top of the engine to avoid gas ignite.
Set the trimmer on the floor, set the gap of the spark where visibility while you pull the string.
Pull the start string and the arc could be seen right on the plug gap. Consider an Arc Purple or Blue coloration are good.
If the arc has not been seen, the Magneto need to be serviced.
Jun 11, 2009 | Husqvarna 28cc Gas Line Trimmer
No start; recoil starter hard to pull.
No. Sounds like the crankcase is filled with fuel.
Mar 24, 2009 | Garden
22" excalibur hedge trimmer has no spark and will not start
remove plug and ground and see if you have spark at electrode.
Sometimes will not fire under compression.
Check that kill switch is not shorted, just remove the wire going to ground and try again.
If not probably bad coil.
Joe
Dec 02, 2008 | Electrolux Gas Hedge Trimmer
Craftsman 22" Gas Hedge Trimmer Logo
273 people viewed this question
Top Craftsman Garden Experts
john h
lnbn1975
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
