This is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
