I need the owners manual to know how to retrieve voicemail messages
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: Blinking Voicemail Light but no Messages
hold you finger for 5 seconds on the page (or find hs) button, that usually clears the blinking beep/light!!!
also make sure no old messages are in the VM inbox!
This worked for my phone!
SOURCE: I can't retrieve my messages from the answering
Manual for most Uniden phones are availible at http://www.uniden.com/index/manuals_results.cfm?cat=1
Check your Voicemail
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Best of luck!!
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
