2004 Jeep Liberty Logo
A
Anonymous Posted on Nov 24, 2011
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
  • 5 more comments
  • Anonymous Mar 14, 2014
    enciende vluz lado izquierdo
  • Anonymous Mar 29, 2014
    Porque Se Enciende La Luz VSA En El Tablero
  • Gallo Giro
    Gallo Giro May 03, 2014
    flashe la luz roja del antirrobo
  • JORGE PAREDES
    JORGE PAREDES Nov 11, 2016
    que significa la luz que dice ESP BAS
  • _-__-___-_
    _-__-___-_ Jan 17, 2017
    this is a USA English, forum.
    no photo of lamp
    lots of warning lamps there. we cant guess
    ICONS or words, you see. lost your camera?
    "Jeep liberty 2004 lights up a light on the right side of the orange board q is"
    RTM read the manual yet.?
    lost it.?
    http://owners.mopar.ca/en/
    Jorge, esp glows when you skid ,did you>?
    the manual told you that if you had read it.
    the below photo of the cluster buy ZJ
    is accurate
    count them 7 warming lamps right.
    all 7 in the book,
    buy the book in spanish?
  • Anonymous Jan 17, 2017
    old post woke up and see as unAnswered
    or cause by the new fixya redesigned pages.
    now worse.http://owners.mopar.ca/en/manuals/2004/2...
  • Anonymous Jan 18, 2017
    the book is free 2004 up
    learn to not lose it
    or learn to down load it , before its goes away.
    every lamp is explained , every one...
    and what to do if it glows.
    some lamps glow and are not a problem.
    if you can not read the English
    then paste it into any on-line translator.
    most are free.
ZJ Limited
Level 3:
  • Jeep Master 17,989 Answers
  • Posted on Nov 24, 2011
ZJ Limited
Jeep Master
Level 3:
Answers
17989
Questions
0
Helped
14449124
Points
60858
Exactamente cual es la luz que ve en su tablero...
Jeep liberty 2004 se enciende una luz en el lado - 11_24_2011_3_45_16_am.gif
Comentenos para poder darle mayires detalles.
  • 8 more comments
  • GILBERTO
    GILBERTO Nov 15, 2013
    JEEP LIBERTY 2005 MARCADA CON EL NUMERO 5 POR QUE SE ENCIENDE
  • Eiling
    Eiling Jan 07, 2014
    ford focus se enciende la luz 18
  • Eustorgio Garcia
    Eustorgio Garcia Jun 20, 2014
    la numero 5
  • Igor Lara
    Igor Lara Feb 09, 2015
    Buenas noches, en mi cherokee sport 2007 se prende la luz numero 20, no encuentro de que es, ojal? puedan responderme, gracias
  • Victor Siordia
    Victor Siordia Jan 17, 2017
    hola disculpa que significa el 17 mi carro lo esta marcando??
  • _-__-___-_
    ok posted to 2011 post , highjakked.
    but someone woke it up
    and said, please help
    so here are the answers.
    to lamps glowing.
    read the manual , before its not free next year. down load it and keep it.
    be wise.
    and read the 4wd pages, 2 times.
  • Oscar D Velasco
    Oscar D Velasco Jan 21, 2017
    Me prende el numero 5. Que significa?
  • _-__-___-_
    _-__-___-_ Jan 21, 2017
    lost the book already
    each lamp has meaning
    lamp 5 is low tire pressure
    or tire sensor faults
    talk to the tire store, they tell you for FREE.
  • Anonymous Jan 21, 2017
    i guess you can not read the USA book above.
    the operators guide.
    sorry it's in English.
    but you can copy the text on the cluster pages
    and paste it here.https://translate.google.com/
    try not to be helpless
    read the manual
    or paste text to the translator
    or go to JEEP and by the book in spanish.
    that way not lost at every flashing lamp.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
8087
Points
8
La luz amarilla que se prende es la marcada con el # 8.Porque sucede esto?. Cual es la solucion a este problema?
  • 2 more comments
  • ZJ Limited
    ZJ Limited Jan 10, 2013
    Se refiere a un codigo de fallo que ha sido registrado en el computador del vehiculo; necesariamente deberas usar un Lectro de Codigos para poder acceder al sistema y conocer especificamente a que codigo se refiere; solamente con este numer podremos darte mayores detalles.
  • ERWIN
    ERWIN Nov 28, 2013
    LA NUMERO 8
  • ERWIN
    ERWIN Nov 28, 2013
    DEL TABLERO DE LUCES
    8 means check engine
    if the book was read
    it states
    get car service,
    or if a technician, scan it.
    2 choices or ignore it.
    like most do.
_-__-___-_
Level 3:
  • Jeep Master 20,706 Answers
  • Posted on Jan 21, 2017
_-__-___-_
Jeep Master
Level 3:
Answers
20706
Questions
Helped
6790749
Points
57965
Welcome to USA>
we are English here and so is forum.
orange lamp? glows. on the "BOARD"?
no photos posted by you.
so no magic answer
expect only wild guessing !
alan pedraza velasco
Level 1:
New Friend:
  • Posted on Jul 18, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8087
Points
Disculpa la 22 que significa?
  • 1 more comment
  • Hector Barradas
    Hector Barradas Jul 23, 2015
    Alguien sabe el significado de la 22?
    22 means , security key failure.
    try other spare key now,
    Sentry Key Indicator Light — If Equipped
    Refer to “Sentry Key Immobilizer System” in
    Section 2 of this manual for more information.
Igor Lara
Level 1:
New Friend:
  • Posted on Feb 09, 2015
Igor Lara
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8087
Points
  • 1 more comment
    20 is page 156 in book above
    means doors ajar.
    if it flashes slow, means all ok.
    RTM
    why no learn to read the manual first then
    ask what is not CLEAR
    20
    quote
    "20. Security Alarm System Indicator Light — If
    Equipped
    This light will flash rapidly for approximately 16 seconds
    after all of the doors are locked and closed to signal that the system is arming. After the alarm successfully arms,
    the light will flash at a slower rate to indicate the alarm
    is set."
    free book, RTM much>?
    then use translate, again FREE
juan carlos
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 01, 2015
juan carlos
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13374
Points
La luz que se prende es ,segun en el cuadro ilustrativo es la numero 5 es como una herradura de color amarillo
    asked 2 times now
    Low tire pressure of tire sensors dead.
    that icon is tire , section view
    the ! means , its not happy.
    the ! means it wants to tell you why its bad.
    we scan it.
    all tires stores here do that for free
    tire sensors can do this.
    1: shows pressure low. or OK.
    2: a dead sensor.
    3: tires too hot.
    4: sensor in sleep mode (drive car 15miles)
    5: sensor battery low or ?
    some cars have 5 sensors, even spare.
    TPMS is the name.
3helpful
3answers
Se enciende la luz del tablero marcada conel 5
No es muy claro; estoy adivinando. Si este es el esquema de su tablero de instrumentos...
El indicador numero "5" se refiere al sensor de presion de los neumaticos.
Esta luz se enciende cuando hay un neumatico bajo condicion de presion . La luz tambien se encendera si existe algun problema con un sensor del neumatico . La luz permanecera encendida hasta que la presion de los neumaticos es correcta o el problema con el sensor se corrige .Esta luz se encendera momentaneamente como una comprobacion de la bombilla cuandose arranca el motor .Cuando el Monitor de Presion de los Neumaticos Light Warning esta iluminado, uno o mas de tus llantas estan considerablemente desinfladas Usted debe detenerse y revisar la llanta lo antes posible ,para inflarla hasta obtener la presion correcta, como se indica en los neumaticos (cartel de informacion del vehiculo). La Ccnduccion con neumaticos no significativamente inflados lo insuficiente hace que el neumatico se sobrecaliente y puede conducir a la rotura del neumatico.
Las llantas desinfladas tambien reduce la eficiencia del combustible y la vida de la banda de rodadura de los neumaticos, y puede afectar el manejo del vehiculo y capacidad de frenado. Cada llanta,incluyendo el de repuesto , se debe revisar mensualmente cuando frio y ajustado a la presion de inflado recomendada como especificada en la etiqueta del vehiculo.
Suerte.
Enciende una luz en el tablero como ancla quiciera saber si es de frenos es una honda crv 2011
que significa en el tablero de honda crv 2001 un foco que se prende 00 off??
9helpful
Que significa chekch
Una señal luminosa "check engine" le está diciendo que la computadora que controla el motor de su auto ha detectado un problema que causa que el vehículo produzca excesivas emisiones. En ocasiones la luz será acompañada por una notoria serie de problemas en la respuesta del carro, como pérdida de poder del motor o dificultades para encender, pero otras veces el vehículo puede operar "normalmente".
Las fallas comunes que pueden causar que se encienda el "check engine" incluyen:
- Falla en componentes del motor como los sensores de oxígeno, temperatura del refrigerante, presión interna (MAP) o de flujo de aire.
- Motor que no enciende debido a fallas en las bujías, cables, componentes del encendido, inyectores de combustible u otras partes del sistema de combustible.
-Fallas en el sistema de control de emisiones como mangueras de vacío rotas o sueltas, el tapón del tanque flojo o desaparecido, o una defectuosa válvula de recirculación de combustible (EGR).
Si se enciende y luego se apaga tras unos instantes, puede ser un problema momentáneo en el sistema. La luz se apaga cuando el problema se detiene, pero la computadora debe haber guardado un código de diagnóstico de problema en su memoria. Si la luz no regresa, puede ignorarla. Sin embargo, si la luz se enciende y apaga intermitentemente, lleve el vehículo para que lo revisen y puedan escanear el computador para determinar que codigos de falla hay almacenados en el.
Suerte (recuerca calificar y comentar esta respuesta).
Como hago para que en el tablero de mi vehiculo no me marque que la puerta esta abaierta cuando las puertas estan bien cerradas?? y la luz del interior se enciende y apaga
Revisa el marco de las puertas, debes tener un PIN que se presiona cuando estas se cierran, que esta fallando. Es raro que todos a la vez, revisa puerta por puerta. A veces se soluciona echandole unas gotitas de aceite WD40.
Suerte.
3helpful
2answers
SE PRENDE UN FOCO DEL TABLERO QUE CREO SIGNIFICA MOTROR Y CREO QUE CONSUME MUCHA GASOLINA.
Asumimos que la luz que se enciende es la que dice CHECK ENGINE, y si ha notado algun consumo elevado de gasolina, es porque algun sensor esta fallando o enviando aviso que alguno de los componentes esta por fallar; generalmente podria ser algun sensor de oxigeno, pero para saber correctamente que medida adoptar tendras que "escanear" la computadora del vehiculo; con los codigos de fallo que arroje el escaner podremos brindar mayores detalles de solucion al problema.
Mantengase en contacto y dejenos saber sus avances.
Tengo problemas con los frenos, se me enciende la luz indicativa del ABS, y el problema es que cuando freno, al momento en que casi se detiene el vehiculo jala hacia la derecha, como si solo frenara ese la...
evidentemente la luz se enciende por un fallo, revise que el caliper o compensador del lado derecho no este muy ajustado y tambien purgue el sistema por posibilidad de aire en el sistema
La luz en el tablero se enciende cuando esta en marcha y dice check engine y low wash
llena de liquido para limpia brisas y ya esta ,este lo puedes localizar a un lado del motor tiene una tapadera amarilla,y la otra esta atras en donde abres la puerta de atras y esta donde esta la luz de atras suerte!!!
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
