And since I didn't buy on from them they can't tell me what to do.. can you help me?
SOURCE: How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address ([email protected]). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address ([email protected]). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as [email protected]. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
SOURCE: How To Set Up PPPoE DSL Connections with a Linksys Router
This Real Did work,WOW Great Stuf...You Made it so Easy My Kid could do it.I like when some one put fixes on the web that really do work Thanks I am going to Bookmark this GREAT Site
Just Past this this site to my Friend.Cool Thanks for the GREAT IFO...
SOURCE: Use 2700 as router only?
there's a way to make the gateway act as a router only but it's not really recommended since there's a possibility that the connection will not be as stable as it should.
anyways you can try the following steps in making your gateway act as a router (not really a router but just a switch and a wireless access point).
- access the router's web user interface by typing http://192.168.0.1 on your web browser
- then click on the "Advanced Configuration Settings"
- select the "Transparent Bridging" option (note: you must configure your wireless settings first before trying these steps since you might not be able to access the gateway's page anymore once you save the changes)
- set the vpi to 0 and vci to 32 if it asked you for those settings. next to 'ATM PVC Search' select the radio button next to Disable. ensure Bridged LLC is selected next to 'ATM Encapsulation'.
- then save the settings
- connect now the new modem to one of the ethernet ports of the 2700hg-d using an rj-45 or an ethernet cable
hope this'll help you.
SOURCE: 2WIRE 2701 router
You must log on to the browser interface of the router (usually for
2wire they use 192.168.1.254) run the set up wizard it will come to a
screen which asks for a key code, this key code is provided by your
ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
SOURCE: connect netgear wpn824 to DSL router using usb connection between
call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
