I have a RCA Universal 3- Unit Remote Control, and I want to program my Sansui TV/VCR combo. I cannot find the Codes to program the remote to work with the tv/vcr.
I purchased a new remote after salesperson said I needed it and IT doesn't work either. I think TV sensor is not working..Can't get it to do anthing with remote.I purchased a new remote after salesperson said I needed it and IT doesn't work either. I think TV sensor is not working..Can't get it to do anthing with remote.
You can't post conmments that contain an email address.
Why am I unable to program the RCA remote control to operate a component?
If you are unable to program the remote control to operate a component, review the following information:
Compatibility If
none of the programming procedures work, the universal remote control
may not be compatible with your components, based on the type of
infrared technology and the age of the components. Some RCA universal
remote controls will only work with components manufactured after 1990.
Distance If
you are testing the remote control after you have entered a code, you
may be too far away from the component or you may not have the remote
control aimed directly at the component. Because the remote control
uses infrared (IR) technology to communicate with components, there
must be an unobstructed path between the remote control and the IR
sensor on the component.
Code Entry Methods If the Direct
Code Entry method was used to enter the codes for your brand and the
unit is still not functioning properly, try one of the automatic code
search methods instead. During automatic code search, the remote
searches for the correct code to program.
Modes For the
remote control to know which component you wish to operate, you must
put the remote control in the correct mode by pressing the
corresponding component button.
Combo Units To program the
remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or
TV/VCR/DVD’s, use the combo codes in the Code List to program the
individual corresponding component buttons. Once programmed
successfully, the TV button controls the TV functions on your unit, and
the DVD or VCR button controls the DVD or VCR functions, respectively.
The codes in the combo section should be tried first, using the Direct
Code Entry method on the TV and DVD or VCR buttons. If this is
unsuccessful, use one of the Code Search methods to program your combo
unit.
Batteries Make sure the batteries are new and properly installed.
Hello You hven't given any specification of the remote control you have. Yet I hereby send you universal remote codes for Sansui herewith. Three digit universal remote codes for Sansui are: 135/ 136 Four digit codes to check with are: 0135 0310. Four digit code for Sansui TV/VCR cobo is: 0310
The remote control that you use for your Comcast box will not operate all functions of the TV sice its a combo model. Your best bet is to purchase a universal remote control from the following website. There are 3 different versions of your TV's model number so make sure you choose the correct one for proper operation. Good luck
Here is a list of codes for your remote. Please follow any of the links below to get your codes. Results 1 - 10 of about 324,000 for rca universalremotecodes. (0.26 seconds)
Search Results
Universal Remote Control CodesCodes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more. www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Code Phillip Universal tv control for vivo tv/ DVD
