Just replaced power cord and tv still will not turn on
Sounds like a bad power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/777/starmen-tom202cabb-power-supply-board-repair-service-no-power-shutdown-etc
Sounds like a bad power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/777/sta...
This is a known issue with this model. The problem is a failure of the power supply board, it is a model TOM202CABB. Here is a link to a repair guide that will show you the parts that needs to be replaced to rebuild the power supply board. The guide references the Emprex model but the power board is the same. The repair takes about 20 minutes and you will need to do a little soldering but anyone can do it.
http://www.ccl-la.com/blog/index.php/solving-emprex-hd-3202-power-problems/
I hope this helps, if so please rate my solution.
BuddyMc
SOURCE: sound lost on digital lifestyles tv
Try unplugging it for a few and starting over, check your connections. If that does not help it is probably broken. This brings you to the bigger problem, It is no mystery why all of these new "no name" TV manufactures are so much cheaper than 1st tier products. Some of it is quality, but the biggest reason you spent a few to maybe several hundred less than the Sony, Toshiba, Samsung, Mitsubishi, etc. is after the purchase support. If your TV is broken chances are it is not getting fixed. There is no such thing as Digital Lifestyle replacement parts, service centers, service manuals, etc. If a company can build a TV then wash their hands of it they can sell it much cheaper. Name brand manufactures produce original replacement parts for years, they set up authorized service centers all over the country and they publish service info for their servicers. You might take it in somewhere for a look, sometimes it is something simple or basic electronic circuit failures that can be repaired with common generic components, but if you need something specific, it won't happen. You say it is "new" if it turns out broken and you can return it, do it, go smaller with a name brand or spend the extra few hundred bucks. Don't get me wrong name brands break too, the difference is they are repaired and you move on rather than throwing it away and buying again. People are discovering there is nothing more expensive than a cheap TV. Good Luck
SOURCE: I need to know the manufacturer of the digital lifestyles tv
the manufactures name is corian usa 800-278-6334 i had this problem and it turned out that u have to use LG codes.i also had to use lg codes to code direct tv sat box
SOURCE: U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
SOURCE: cannot find code for digital lifestyles remote control
LG codes work with digital lifestyle.
SOURCE: my digital lifestyle tv in not powering on. what
i,am not getting power to tv it is not comeing on
