Jenn-Air JED8430 Electric Cooktop Logo
Barbara babin Posted on Nov 21, 2011
Manual for Jenn Air SVE47600W slide in cooktop and oven
4 Related Answers
Anonymous
  • Posted on Feb 08, 2008
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Anonymous
  • 1383 Answers
  • Posted on Apr 25, 2009
SOURCE: Need To Replace the Cooktop of my Jenn-Air downdraft
open that two screw also check there is other screw or not?
Also check there is any locksystem if u find any lock then open it then remove the cook top easily.
Anonymous
  • 15935 Answers
  • Posted on Apr 29, 2009
Here is a blowup diagram of the cooktop.
CLICK HERE
Looking up the service manual - it is no longer available.
Hope this is helpful.
Thanks for using FixYa!!
Anonymous
  • 1305 Answers
  • Posted on May 09, 2009
SOURCE: Jenn-Air JGD8345 Gas Cooktop. What are the ducting instructions?
go to :
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JGD834&siteCd=JA_EN_US#installation_instructions
and pick your installation guide from jennair directly...
Good luck
I am trying to repace the bake element in my jennaire electrical stove. There is a wire coming into the side of the connector. Does that wire simply pull out. I cannot understand how it connects. Thanks
If you are talking about the terminals of the oven element, the wire coming in is connected to the spade connector. The spade connector slides off the oven spade terminal.
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
1helpful
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Jenn-Air gas Cooktop fire is low
www.servicematters.com/maytag_library/docs/16010492.pdf service and troubleshooting manual above.
I need an installation manual for a cvg4380p Jenn-Air cooktop
Hello Chuck,
Your request is for the Jenn-Air CVG-4280P gas cooktop installation instructions, even though the info at the top of the page states a JED8430 electric cooktop,
If I've got your request correct, here's a link to the installation instructions for the CVG-4280P cooktop.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380PII.pdf
If you'd also like the owner's manual for that same cooktop, here's the link for that too:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/CVG4380P.pdf
Hope you find this Very Helpful and best regards!
Merry Christmas!
How to start the self-cleaning cycle in jenn-air sce30600?
An electric cooktop uses a great deal more electrical energy than a gas cooktop. The electric portion of the gas cooktop runs the electronics (clock, timer, ignitor, oven light, etc.), and these are small electrical loads. An electric cooktop uses more electrical energy cooking a batch of, say, pasta sauce, than a gas cooktop would normally use in a month or two. There just isn't a good comparison as there is such a broad difference in the electrical usage of the two units.
Sep 20, 2009 • Cooktops
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
2helpful
2answers
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
1helpful
Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
