The camera worked 12 hours ago for taking pictures. It will not turn on this morning. Have always used alkaline batteries and the replacements are the same as what was in there.
Hi Kris - If the camera worked before changing the batteries, but now it doesn't; check the batteries for proper insertion. If just one battery was installed incorrectly, the camera will not power up. Also, check the charge of the batteries. If even a single dead battery was included in the mix of new batteries, the camera will not power up either.
If all these conditions check out ok, the problem may be related to defective hardware (power switch, lens, etc.). When the camera is powered on, it goes through a quick self test. If any of these self tests fail, the camera shuts off immediately. This will often require that the camera be evaluated professionally. Hopefully, you'll find the problem is battery related.
