Hamilton Beach Water Cooler with Storage Cabinet Logo
Posted on Sep 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hamilton Beach 87330 water cooler
The water cooler wont stop chilling the cold water. Normally, it would shut off once the chilled water has reaches a certain temperature, but now it runs continuosly. any ideas how to fix??
  • 1 more comment
  • seenbeetwo Oct 13, 2008
    My water cooler is only heating water to very high tempature not cooling at all ,had it less than a year what should i do?I'm not sure if cooling motor is burnt out (I did smell A something burning before this problem) is it covered by warrenty or what any suggestions please let me know thanks.
  • markmacdonal Apr 19, 2009
    Same thing for me. UGH! Super hot water, tepid cold water. I'm trying the rest from below.... cross your fingers!
  • Anonymous Mar 26, 2014
    is not dispensing cold water just room temperature
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7357
Points
15
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Anonymous
Level 1:
  • Posted on Nov 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7357
Points
Model 87330 doesn't use compressor and freon, it is thermo electric
Anonymous
Level 3:
  • Master 750 Answers
  • Posted on Oct 14, 2008
Anonymous
Master
Level 3:
Answers
750
Questions
0
Helped
491055
Points
2063
Hello mmmm,
Welcome,
how old is the unit?
And what did it cost you?
It has a bad thermostat.
Try unplugging it for 5 minutes and see if it resets.
If it runs continuously the compressor will soon burn out and die!
If not do not spend more than half of what it cost to repair it!
This is the rule of thumb.
You said ,The water cooler wont stop chilling the cold water. Normally, it would shut off once the chilled water has reaches a certain temperature, but now it runs continuously. any ideas how to fix??
Thank You for using our site for advice,
huuum
Please remember to leave a rating!
  • Anonymous Oct 14, 2008
    For the guest that posted that they had the cooler for less than a year.
    If you bought it new,then you should have a 1 year warranty.
    Call the number in the user manual or in the papers that came with the cooler and they should rectify your problem or replace the unit!
    If it was from Home depot or any large box store they will let you return it or exchange it with a receipt!
    Thank you for using our site.
    Huum,
    Another guest
    Said,my cooler doesn't get cold, what I mean is the water isn't as cold many
    other coolers it's just above tap water. I looked for adjustment screw
    or switch with no luck.
    It sounds like a bad thermostat or low freon.
    If it's new return it.
    If you plan on fixing it.
    Do not spend more than half the cost of the cooler!
    Let me know what you do!
    huuum
Anonymous
Level 1:
New Friend:
  • Posted on Feb 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7357
Points
I had the same problem, keep chilling the water (blue light stays on), I cleaned the unit like the manual says and problem went away
Our Hamilton beach water cooler makes a constant noise as it cools the water. The cooler does not shut off once the water is cold. Series #A0370CT.
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Cooling unit does not shut off
Replace Thermostat and find the model number, Sea Breeze
10helpful
2answers
Hamilton Beach 87330 hot water problem.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
3helpful
Hamilton Beach water cooler dysfunction.
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
5helpful
My hot water on model #87330 cooler has stopped working the switch is turned on in the back
Unfortunatly this is going to be a bad heating element or high limit thermostat, It's going to be cheaper to buy a new one or just make do with cold water. Sorry I can't be more helpfull but i worked on these things for a while and the company i worked for would rather buy new then put time effort and parts into a $100 water dispencer.
if I can be of any more assitance please feel free to comment again.
5helpful
3answers
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
3helpful
4answers
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
3helpful
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Top Hamilton Beach Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
