Televison & Video Logo
Anonymous Posted on Nov 21, 2011
Tlxo4240b bright colors, whites and skin tones seem to glow and blur a little (I call it radioactive looking) this was a black Friday Walmart purchase that we aquired at an estate sale. At first the
I have tried adjust everything bit by bit, one catagorie at a time, color temp, contrast, brightness, etc.
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on Nov 21, 2011
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2250246
Points
16163
Excess brightness will cause blloming of the image. Reduce brightness.
  • 2 more comments
  • Anonymous Nov 21, 2011
    already adjusted that and tried again without any improvement. thanks though! :)
  • Fred Yearian Nov 22, 2011
    Some people get a very large screen aand try to watch it from too close and will get this effect. The way the LCD works can cause blurring if viewed too close as the process is like little light valves for each pixel. If you have every taken two polaroid lenses and rotated observing the light being cut off at various angle, the LCD works similarly.and viewing angle can affect the clarity. SInce you got this at Walmart, go to the store and look at their demo units of the same model and if your unit looks different than the identical one at the store return it under warranty.
  • Anonymous Nov 22, 2011
    thank you for your comment, but I do not have warranty as we purchased at estate sale (we knew the daughter of the deceased who had purchased the tv from walmart, that's how we knew age/history of purchase etc). I'm afraid I have not described the picture issue very accurately because this is a very obvious picture quality problem, not a "blurry when viewed too close" The picture is not any better from afar and does not look like any stores unit. Truly it looks as if everyone is radioactive , like some kind of computer generated effect you would see in a sci-fi movie. LOL.
  • Fred Yearian Nov 24, 2011
    I am running out of suggestions... however depending upon where the video is coming from, there is a possibility that the video is noisy due to any one of several things such as a ground loop that causes the video syncronization to "dither" the image which would cause the problem. Verify that all connections are good and there is a good grounding system... Often used equipment has ground pin broken off plugs, etc... and grounds in video or HDMI or Svideo cables can get broken. Often peopl have more than one set and cables all over their house picking up noise that can dither the picture. Some sets in the system may be fine, but another tied in on a different wall receptacle will be bad due to the house wiring.
Best picture calibration settings
For any TV; irrespective of its brand or type, set the contrast to 70 to 80%; brightness to 30 to 35% will produce a clear and vivid picture in B/W. Set the color to Zero, and check this first. After you have satisfied with the picture in Black/White [B/W], advance the color intensity, according to your viewing taste. This adjustment will depend on individual taste. Anyway, note the skin tone of the news reader at the studio. Take this color a reference. That's all.
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
tip
Makeup For Radiant Skin
You can make your skin glow with the appropriate makeup products. its essential to apply a moisturizer or a hydrating face cream every morning no matter your skin type or age.<br /><br />Choose a sheer liquid foundation and apply it onto a cleansed and well-moisturized face. If you want to make your foundation flawless-looking and to make it stay put on for longer consider applying a makeup primer before the foundation. The aim of a primer is to prepare the skin for the makeup application, to pamper the skin and creating a protective base for longer- lasting, natural looking foundation.<br /><br />Consider applying a light-reflecting face powder if your skin is absolutely clear and free of pimples, scars, blackheads, whiteheads, brown spots and other skin imperfections. Apply the powder with a big, round powder brush over the entire face or only to the cheeks.<br /><br />Use a blush in pink or peachy shade as these shades suit almost everyone and look more natural. Apply the blusher with a blush brush and build the color gradually. Use a powder blush as it last longer than a cream or gel blush. Choose brighter shades as they will make your skin glow and will freshen your skin.<br /><br />Lipsticks or lip glosses in brighter shades will also make your skin glow. First outline your lips with a nude lip pencil or with a natural-toned lip liner and use a lipstick brush to apply the color evenly. Remove the excess with a tissue and then apply a second layer for a more saturated lip color and for a longer-lasting lipstick color.
on Nov 22, 2010 • Health & Beauty
tip
Tips on choosing the sunglasses color.You can't go wrong with basic black....
Tips on choosing the sunglasses color.You can't go wrong with basic black. Everyone should have at least one pair of gigantic black sunglasses for everyday wear - they're so Breakfast at Tiffany's. For extra movie-star appeal, make sure the lenses are as dark as possible.<br /> Pay attention to the colors you wear most often. You want your sunglasses to work with the majority of your clothes. Do you wear cool colors most often? If so, try to stay with cool colored sunglasses in shades like black, gray, blue, and silver. If you tend to wear warmer colors, look for brown, red, gold, or similar warm-toned sunglasses.<br /> Try to buy shades in one of the colors that flatters you most. Shades that flatter your skin and hair coloring will bring out your features and make you glow. Not sure which colors look best on you? See my article How to Find Your Perfect Colors.<br /> Have fun and experiment with cheap, colorful frames. Neon sunglasses are a huge trend for summer 2009, so I recommend having some fun and trying the trend out with some inexpensive frames. Sometimes it's fun to wear ridiculously bright, cheap sunglasses. Keep the rest of your outfit simple & classy but go wild with your shades for a look that's very modern and right-now.
on Nov 07, 2010 • Clothing Accessories
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
I have a toshiba 56hm195, colors skin tones are washed out, reds
I'm having the same problem; have you found any solutions yet?
1helpful
2answers
In the past few day i've noticed the picture is
BRIGHTNESS. Your owner's manual probably says that the brightness setting is used to control "brightness" or "picture intensity" or something other fuzzy non-descript term. The truth is that brightness is used to set the BLACK level in the picture.
On most TVs and projectors in use today, brightness is set too high. That's because people think "a bright picture is good, so I will set it as bright as I can get." Well, that's nice in theory, but entirely wrong in practice. Setting the brightness level too high makes a black tuxedo look gray rather than black. It muddies up the shadow areas, and reduces the overall snap and crispness that the picture would have if properly calibrated.
To find the right setting for brightness, go to the image in your movie that has textured blacks and hopefully some shadow/low light areas in which there is detail. Then freeze on that frame. As you move the brightness control down, the intensity of the blacks will increase, and shadows will get darker. As you move the control all the way to zero, you will (hopefully) see that the low light shadow areas will also go to solid black and lose their detail.
The optimum setting for brightness is achieved at just the point where true black objects appear as black as your system will make them while retaining as much visible detail in the shadow areas. Above this point the blacks appear to go grayer. Below this point you lose detail in the shadows. On many video systems, this optimum point is toward the lower end of the brightness scale. But find the point that looks correct to you regardless of where it is on the scale.
CONTRAST. The contrast control is similarly confusing. It is also often set too high on the theory that contrast is good, and therefore we might as well get the most we can out of our set by turning it all the way up. In fact, the contrast setting is used to control the intensity of the brightest highlights in the picture, so it is (oddly enough) the opposite of brightness control.
First, find your test scene in which you find textured whites in bright light, and freeze that frame. You are looking for the brightest elements in the picture in which you want to retain visible detail.
Let's assume you have a whitewashed fence in sunlight. If you start with the contrast set low, the fence will appear light gray rather than white. As you move the contrast control up, the fence will get whiter. Eventually details in the texture of the fence will begin to disappear.
If you continue to push contrast past the optimum point, the wood-grain texture of the fence will go solid white and all visible detail will be obliterated. Push contrast up even a little further, and our fenceposts might actually appear to expand very slightly due to a glow around the edges. This phenomenon, called "blooming" is a definite sign that your contrast setting is overcooking the image (and maybe your picture tube as well—don't ever leave the contrast control set this high!!!)
Find the point at which whites look white while retaining as much texture detail as possible. This is your optimum contrast setting. On most video systems, this setting is toward the higher end of the scale, but it can be anywhere. Find the point that looks correct to you. (By the way, unlike TV's, digital projectors will not bloom)
Now…note the following: brightness and contrast can be to some degree interactive. Your new contrast setting may have affected your brightness. So return to the brightness scene and verify that your blacks are still black, and you still have maximum detail in the shadows. Adjust it if necessary, then return and adjust the contrast setting once again if necessary. (You can see that this is much easier if the black and white elements you are testing all appear in the same image!)
COLOR. The color control on your set determines the level of color intensity in the image. One of the most common errors people make in calibrating their video systems is overdriving the color. That's what makes Larry King look reddish-orange on the TV at the gym. Overdriving color is common because once again, people naturally think, "I want to get as much color as I can out of this color TV, so I will crank it up some to make sure I get the most out of it!" No. Bad mistake.
If you move the color setting down to zero you will notice that your picture will turn into a black and white image. The optimum setting for color is achieved by increasing the setting just to the point where colors look natural and not a bit more! Flesh tones should look natural and without any hint of an unnatural glow. Grass should look naturally green rather than screaming spray-paint green.
When adjusting color, make sure that your test image has relatively unsaturated colors. Flesh tones or natural landscapes are ideal. It is impossible to set color properly if you are using a brilliant red Ferrari as your test subject.
On the large majority of video systems, the optimum setting for color is somewhere near the middle of the scale. However, trust your eyes for the optimum setting and think "what looks like the most natural, accurate reproduction of reality?" Any overdriving of color will make the image look artificial.
TINT or HUE. The tint control adjusts color balance rather than color intensity. It is an easy control to set properly, but for some reason many people don't get it right. When flesh tones look either too green or too magenta, a phenomenon you see with amazing frequency, it is because the tint control is not set properly.
Find a human face and freeze-frame it. (In choosing your test subject, note that lighter skin tones will show errors in tint more readily than darker skin tones). As you move the tint control to one end of the spectrum, the face turns green; as you move it to the other extreme, the face turns magenta (red+blue).
The correct setting for tint is the point near the middle of the scale at which you can detect no hint of either green or magenta. It is the most neutral point between the two extremes. The flesh tone looks the most natural at this point.
SHARPNESS or DETAIL. The final setting is sharpness or detail. Now, pray tell, who in their right mind wouldn't want the sharpest, most detailed picture they could get? And since there is a control that lets you turn it up, why not turn it up? That's what many folks do, and of course it's exactly the wrong thing to do.
The sharpness control adds processed information to the picture that is NOT part of the original video signal. It adds artificially highlighted edges, and makes the picture look less natural than it otherwise would. This is most evident along the continuous edge of a dark object against a middle-toned background. When sharpness is overdriven the dark edge will be outlined by a white ringing effect that increases contrast just along the edge of your dark object. That edge "highlighting" effect is created by the sharpness control. It is an artificial manipulation of the image. It wasn't in the original scene, and it shouldn't be on your screen either.
On most televisions, the optimum setting for sharpness is zero. On many digital projectors, the optimum setting is either in the low or middle part of the scale. Picture tube televisions and digital projectors behave differently in this regard; on a digital projector it is often possible to fuzz the image by setting sharpness too low.
Now look at your picture with the sharpness turned down or off depending on what works best on your system. You will see a smoother, more natural image. It might take some getting used to, since you may be accustomed to viewing video with all the artificial edge enhancements that create the illusion of added sharpness.
However, when the interference and noise from the artificial sharpness enhancer is removed, you are seeing the most genuine reproduction of the video signal that your projector or TV is capable of. And if you view it for a while, you will gain an appreciation for just how smooth, natural, and satisfying the picture can really look.
Colors glowing to bright
The coolant liquid ,that is inside the picture tube lenses need to be replaced. this helps to keep the internal picture tube temperature cool down. and the focus quality. the cost to replace it could be around 250.00 dependin on the tech . in repair shop 350.00 any questions Jus ask I'm glad to help you
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
