Home Logo
Anonymous Posted on Nov 20, 2011
INSTALL LITHONIA LIGHTING 4' STRIP T12 120V
4' T12 120V- UPC# 7 84231 01697 0
Wylie Johnson
Level 3:
  • Master 827 Answers
  • Posted on Nov 24, 2013
Wylie Johnson
Master
Level 3:
Answers
827
Questions
Helped
251043
Points
1813
Depends on where you want to install best thing is to hire an electrician to do this
1helpful
How do I repair Lithonia ECR M6 LED Emergency/Exit Light combo. No emerg lights when test button is depressed, no led lights from AC? just a flash when test switch is depressed? is it the small transf
Fixtures are covered by Lithonia Lighting 24-month warranty against mechanical defects in manufacture.
All life safety equipment, including emergency lighting for path of egress must be maintained, serviced, and
tested in accordance with all National Fire Protection Association (NFPA) and local codes. Failure to perform the
required maintenance, service, or testing could jeopardize the safety of occupants and will void all warranties.
Note: Specifiations subject to change without notice.
Actual performance may diffr as a result of end-user environment and application.
Standard
Catalog Supply Input Pallet Carton
Number UPC Description Voltage Wattage Qty. Qty.
ECR LED M6 784231874516 Red 120/277 3.8 108 6
ECG LED M6 784231874592 Green 120/277 3.2 108 6
ECR LED HO M6 784231874561 Red, high output 120/277 3.8 108 6
ECG LED HO M6 784231874615 Green, high output 120/277 3.2 108 6
Accessories: Order as separate catalog number.
ELA WG3 Wireguard (back mount only) 1
ELA LED M12 Single remote lamp2,3
ELA LED T M12 Double remote lamp2,3
ELA LED WP M12 Single, weather-proof remote lamp2,3
ELA LED T WP M12 Double, weather-proof remote lamp2,3
Notes
1 See spec sheet ELA-WG.
2 See spec sheet LED-Remote Lamps.
3 Only available with HO option.
11 5/8 "
7 3/16 "
1 5/8 "
Integrated Exit-Unit Combo
12-5/8"
(32.1)
8"
(20.3)
4-3/8"
(11.1)
5-3/8"
(13.7)
1-7/8"
(4.8)
LED Unit
LED Combo
LED Exit
15 (38.1)
3-3/4
(9.5)
5-3/8 (13.7)
12 (30.5)
3-3/4
(9.5)
2"
(5.2)
4-1/2"
(11.4)
9"
(22.9) 8"
(20.3)
20"
(50.8)
12"
(30.5)
All dimensions are inches (centimeters).
Shipping weight: 3.6 lbs. (1.6 kgs.).
ECR LE
Setting time on lithonia msx12
google that lithonia msx12 for wiring diagram. I did and found it to be a home depot motion detector. all the information is there, including sensor setting instructions.
How do you remove a lithonia floresecent light cover
It either spins off or it is spring loaded. Just pull down.
Trying to install tws 70s 120 small wall pack need instruction
so where are you installing them, outside of home?
black wire to power white to neutral and green to ground, most will install with the hardware that comes with them
We have 48" lithonia flouresent
even if there is power at the sockets, ballast may not have power to fire off the lamps, how old is this fixture, and you need to replace the ballast same as in fixture, if you replace ballast make diagram of wiring so you can rewire it like it was wired from store.
Extra blue wire what is it for
48" light fixtures come in single lamp, two lamps, and four lamps. The ballast must match the supply voltage and the amount of lamps the fixture has.
2answers
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
8helpful
2answers
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
