Accutron Swiss Watch by Bulova 26B44 Logo
ELLIS COX Posted on Nov 20, 2011
BULOVA ACCUTRONE E66831 M8 14KT WIND STEM AT 4 OCLOCK NEED TO KNOW IF IT IS WORTH MORE THAN THE GOLD CASE THANKS
gary meyers
Level 1:
Problem Solver:
  • Contributor 23 Answers
  • Posted on Jun 05, 2014
gary meyers
Contributor
Level 1:
Problem Solver:
Answers
23
Questions
Helped
3836
Points
84
The M8 indicates this watch was produced in 1968 and probably sold for 250-350,this is a tuning fork watch and they are highly collectible and worth up to twice the value of the gold or more depending on the model and condition
2 Related Answers
Anonymous
  • 2501 Answers
  • Posted on Apr 08, 2010
SOURCE: I have a Bulova Accotron (M7) Is it automatic
If you go to http://www.bulova.com/service/servicecenter.aspx, you will be able to locate the nearest service center, who will be able to advise you. (incidentally, after such a long time idle, it may need servicing).
Anonymous
  • 1970 Answers
  • Posted on Aug 15, 2010
SOURCE: what is the worth of a bulova accutron 14kt gold
mcdevito75 here, Bulova Accutron, nice watch, of course there are many, many factors that go into the value of any watch, depending on Maker, Model, Condition of the watch also. I would figure your Bulova Accutron is in the area of $125.00------- $200.00 range. Your best bet is to find a jeweler in your area or an appraiser, even online for the latest value of your watch.
B24007 M7 waterproof stainless steel railroad approved no stem or buttons
It's an old accutron 214- manufactured 1967. Of course it depends on condition,but the 214 Accutron is very popular and even not working should bring around $50.00 if it is complete, no missing parts. It could possibly bring $75 or more.
What it worth
You ask "what it worth" and show a watch so I guess you want to know the value of a watch.
The resolution of your photo is rather bad but it looks like aBulova Accutron. You are not specifying the materiasl, presume it's not gold. Depends how old is it - yours looks like a vintage model and if in good conditin, might have some value. I can't really appreciate it's real conditiom, photo is not favoring. I guess it should worth about 100 dollars but you should take it to a jeweller or to a pawn shop and get it evaluated.
TIP: Go to ebay and browse all those Bulova Accutrons on sale, if you see some simoilar to yours.
Aug 06, 2015 • Watches
2answers
Value/ year made
The year made cannot be determined from the SN. Since the '50s Bulova used a 2 character date code, usually below the SN. The letter is the decade, the number is the year. For example, M4 is 1964, N6 is 1976, O5 is 1985, etc. As to value, if it is from 1960 through 1976 (M0 thru N6) it is a "true" Accutron, with a tuning fork movement, is collecrible and valuable, and the actual value depends on which specific movement and which case. Some 1977 (N7) Accutrons are akso collectible rtuning fork watches, but some 1977s are Bulova's first quartz watches, and of no value. Bulova eventually went mostly automatic (self-winding mechanical movement) with their Accutron line. Those are well-made, mid to upper-mid level watches, and of no particular value beyond that of most any good used automatic. Note, however, that there have been numerous versions of the automatic Accutrons, some fancier and nmore expensive than others, and, s ith any good watch, original cost will have an effect on value as a used watch. For example, that retailed at, say, $500 new in 2009 will be worth more today than one that was $250 new in 2009 (assuming comparable condition). There are also now some Accutron IIs, which mimic, in looks and the sweep second hand, the original tuning fork Accutrons. However, while they are well-made watches, they are just another nice quartz watch.
Any idea what a Bulova watch, 14K white gold, number on back case 962158. Any idea what it is worth?
I'd need more info. First, is it a "real" Accutron, made from '60 to '77, or is it one of the things Bulova kept calling Accutrons after they stopped making the tuning fork movement watches? The quartz so-called Accutrons are just a nice old watch, not worth anything special. The self-wind "Accutrons", which Bulova is making now, are just a nice, mid-range aurtomatic watch. On the back of Bulova watches is a date code, usually right under the serial number (SNs themselves really mean nothing where Accutrons are concerned). The code is a letter and a number. If it begins with the letter M, or if it begins with the letter N and is followed with a 0, 1. 2. 3. 4. 5. or 6, it is a "real" Accutron, and is collectible. Some with N7 (1977) are also, but it depends on the actual watch. Bulova did make some quartz so-called Accutrons in '77. If it's a '60 thru '76, and SOME '77s, it has value beyond the scrap gold price. SOME Accutrons are even worth thousands of dollars. White gold Accutrons, compared o yellow gold or stainless, are rarer. Next, WHICH Accutron is it? is it a 214, a 218, a 219, a 220, a 224, or a 230? If it's a man's watch, it is very unlikely to be a 220 or 230 series, If it does not have a winding stem on the side, it is a 214. 214s are the most valuable. If it has a setting stem at 3 o'clock or 4 o'clock, it is either a 218 or 219 (I'd have to open the back and look at the movement to say which ine). If it says "Accuquartz" on the face, it's a 224 (NOT a quartz - the 224 Accuquartz is a hybrid of tuning fork and quartz crystal). Once we know the movement series, we need the case type. Certain cases are much more valuable than others. Then there are the Spaceview, the Astronaut, and the Deep Sea, 3 specific models they made, which are more valuable than most (but not all) of the other cases. The best I can say right now is that, being white gold, there's a good chance it's one of the more desireable specific models. If it's a 214, ESPECIALLY if it's a 1960 (M0), it's worth quite a bit more than just the gold content. To be more specific, I'd have to see a picture of the watch, which I don't think can be posted here. Try looking up "Accutron" on Ebay and see if you can find one that, if yours has a stem, has it in the same place as yours, with the exact same case - same shape, and exact same lugs (the things on either end where the band or strap is attached). Read the description. The description will probably say the movement (214, 218, etc - in fact, the movement may even be in the listing title) and if it is niot just a plain round case, probbly will say the case type (Alpha, Asymmetric, Butterfly, etc.). If it's an Astronaut, a Spaceview, or a Deep Sea, it will certainly say that. Also, look at the Accutron section of the Bulova entry in Wikipedia. (Yeah, I wrote it, but it has info that just might help you pin down exactly what you have) When you find out more about which Accutron it is, post another question under Axcutron watches here. I'll check every couple of days for the next week or so, and if I see your post, I'll narrow down the value some more.
What is the worth of a bulova accutron 14kt gold mother of pearl face serial #59252 worth
5helpful
3answers
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
1helpful
RUNNING FAST
Accutron is made by Bulova. Follow this link and click on Accutron: http://www.bulova.com/index.aspx At the bottom of page click on CONTACT US. Rate me, please.
Top Accutron Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Accutron Watch Expert? Answer questions, earn points and help others
