SOURCE: dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
SOURCE: Noisy dryer with long dry time
check to see if the fans are loose if so replace them this will also cause poor drying time.iI find its better to dismanttle these dryers and check the rollers,belt and jockey pulley at the same time.they look hard to work on but they are easy just take you time theres generally no wires to undo.
SOURCE: My Asko dryer does not dry clothes. It shuts off
It is quite common for lint to cover the blower on these units, making it impossible for the dryer to move any air.
1)remove the lower panel. you will need a T20 driver for this and may need to tip the dryer slightly to the rear
2)remove the left part of the blower plenum. this is held by 3 plastic tabs and a T15 screw
You will now see the blower wheel, it is a squirrel cage type. Check for lint buildup, broken vanes, or string/thread wrapped around the shaft.
if there is no problem with the blower then there is another reason you are not moving air. let me know if this helps
SOURCE: I have a Asko dryer T700. Runs but doesn't. Vent
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
