Access your voicemail, and choose the persoal options option, and you can then change your voicemail message, or choose a standard message with your number. good luck.
The "10B1" message on your Panasonic KX-TGD390C phone may indicate that your voicemail box is still full, even if you've deleted all the messages. This could be due to some saved or undeleted messages in a different folder or some other issue with your voicemail settings. To clear your mailbox and resolve this issue, you can try the following steps:
Access your voicemail box: Dial your voicemail access number. It's typically a number provided by your phone service provider, such as "123" or "555."
Follow the voice prompts: Once you're in your voicemail system, listen to the voice prompts carefully. There should be an option to manage your messages or change your mailbox settings.
Delete all messages: Even if you've already deleted messages from your phone, there may be some messages still stored in your voicemail box. Use the voicemail system's options to delete all messages.
Check saved messages: Some voicemail systems have a separate folder for saved messages. Make sure to check this folder and delete any saved messages if they exist.
Change mailbox settings: If you cannot find any messages in your voicemail box and it's still showing as full, you may need to access your mailbox settings and reset or reconfigure them. Look for options related to mailbox size, message retention, or other similar settings. You might need to contact your service provider for assistance if you can't find these settings.
Reboot your phone: After you've taken the above steps, it's a good idea to power cycle or reboot your Panasonic phone. This can sometimes help refresh its connection to the voicemail system.
Contact your service provider: If you're still experiencing issues after trying these steps, it's a good idea to contact your phone service provider's customer support for assistance. They can help you troubleshoot and resolve any voicemail-related problems.
Remember that the specific steps and options may vary depending on your phone service provider and the voicemail system they use. It's essential to follow the prompts and options provided by your voicemail system when you access it through your voicemail access number.
Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
Depending on your wireless service provider, the method for changing your voice mail greeting or voice mail password might differ. You should be able to access the options for changing your voice mail greeting or voice mail password when you check your voice mail. For more information, contact your wireless service provider.
You will need to log into the voicemail system as you would to check your messages. There will then be a number to press (listen to the voice prompts) for voicemail options. Somewhere in there will be the option the change greeting/message. If you do not pay for a voicemail then you will have to live with the standard one your service provider uses, although you may be able to change "your call has been forwarded to the voicemail box of "JOHN DOE", is currently unavailable. This would be changed the same way I stated above.
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is. When you log in to check your mail, the lady says, "welcome to Partner......"
It is usually under message menu. try under setting of this menu. Alternatively you can use one more method that will sound funny but works. Press and hold the No. 1 key and see which number it is dialing. If the voicemail is already set it will be shown to you, edit this from the phonebook to your desired number. If the Voicemail has not already been set you will be prompted to enter you the voicemail number. Fill in the desired number there.
ACCORDING TO THE MODEL NUMBER THIS PHONE DOES NOT HAVE AN ANSWERING DEVICE. IF YOU HAVE VOICEMAIL - YOU MUST HAVE THE PHONE COMPANY'S SERVICE FOR VOICE MAIL. IF YOU HAVE A STUTTERED DIALTONE WHEN YOU HAVE MESSAGES THEN IT PROBABLY COMES FROM YOUR TELEPHONE COMPANY. CALL THE PHONE COMPANY AND ASK FOR INSTRUCTIONS TO CHANGE THE GREETING ON VOICEMAIL.
