Question about Toro Garden
Toro Lawn Mower Won't Start
We changed the spark plug, checked oil and gas. It is a 6.5 self propelled recycler mower. Any ideas?
  • 4 more comments
  • mjvannice Nov 08, 2008
    just quit suddenly. It tries to start and run for just a second and then acts like no fuel or an auto shut off. When you try to pull start it right after that you get nothing. Wait about a minute and it will do the same thing again.
  • tcar32909 Jan 11, 2009
    ran it out of gas, when i added new gas and tried to start, it started and runs for like 1 or 2 seconds and quits. Hit the primer bulb and it does the same thing over and over again.
  • remnbee Feb 21, 2009
    I have a Toro two cycle lawn mower. It has set for a year or so. I got it started using an engine starting spray. At first I had to keep chokeing it, then it continued to run but speeds up, then slows, then up then slows. It does this at all speed settings. What is up with this?
  • Scott Redwine Apr 27, 2013
    I have a personal pace Toro that has had several problems starting and running. First was simply the gas cap being to tight. Then it had gotten to the point that at would'nt start or run at all so i rebuilt the carb and now i cant get gas to the carb. But if i take the bowel off the gas runs out just fine. Any ideas?
  • Anthony Artis
    Anthony Artis Mar 22, 2014
    Just cleaned the needle valve as suggested and it worked. thanks for the advice, ive been trying to get mine started for a few days now, didn't store it properly, now I know. thanks again for the help.
  • doug woodley
    doug woodley Mar 28, 2017
    someone put mix gas in it ran ok wont start now
This is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 1 more comment
  • dasjr May 23, 2011
    yes that was it thanks nobaddog!
  • tomoconnor Aug 13, 2011
    I just did this and it worked perfectly on my Model 20073/A/20027/A (not sure which it is...not electric start). I don't know much about gas, but after 3 years of sitting idle it had congealed into a messy glob. The entire bowl was caked. I used an old plastic butter container to both catch the first squirt of gas and conveniently jam under the plunger to stop the gas flow so I could free my hands. This was vital. To clean out the holes in the nut I used compressed air. worked great. Reassembly tips... 1) do not unjam the plunger yet... 2) put the nut into the bowl FIRST. 3) now inspect the orientation of the bowl to the plunger...it fits a certain way and if you don't figure it out ahead of time, gas will flow while you're frantically turning the bowl trying to get it to fit 4) put paper towels under plunger area before the big moment 5) it's time...QUICKLY remove the butter cup (or whatever) and put the screw/cap combo into place and rapidly screw into place. The gas will flow throughout this process, but it will stop once it is fully seated. 6) tighten nut. For what it's worth, the mower started on the first pull all thanks to Nobaddog's suggestion. 7) you could save yourself a lot of drama by emptying the gas from the mower which is not what i did.
  • soonercary
    soonercary Oct 19, 2012
    THANK YOU! This did the trick and saved me a ton of money. I let the needle valve soak in some De-Solve-It for a minute and stuck a spray bottle tube in the top and forced it through the holes by pumping the sprayer. Put everything together and it fired right up.
I have a Toro Mower that I think this is its fourth season. It died on my wife several weeks ago and I couldn't restart. Started the next day and I finished our small yard. Next week I mowed front yard, killed it and went to the back. Wouldn't restart. Restarted next day then died after two passes and now won't do anything. Plug looked questionable so replaced it but nothing. Doesn't fire or try to run.
Posted on Jun 09, 2010
There is a green ground wire coming off the coil, I found the other end loose down below the flywheel. Can this be grounded anywhere on the motor or do I have to remove the flywheel and figure out where it is supposed to be attached??? Could this be why mine isn't starting???
Posted on Apr 21, 2011
Toro lawn mower will start up after it sits but then dies minutes later after that I cant get it to start at all. Changed the oil and air filter
Posted on Jun 13, 2009
Basically its a gasoline engine check for
  • spark & continuity in coil
  • fuel & passage of fuel
  • carburettor float check
  • worn out blade
  • fly wheel key
  • stale fuel
  • oiling up engine        if the fuel line till manifold is right & spark is right the engine will start
Posted on Dec 02, 2008
I have an older (mid-70's) Toro (Model 20586) and it was doing the exact same thing. That fix about the bolt/jet in the bottom of the carburetor bowl worked for me. Saved me the $419 I was contemplating for a new Toro.
Posted on Apr 27, 2010
  • 48 Answers
Not enough info - did it quit suddenly ? was the mower tipped so that the air filter is now plugged ? need some background
Posted on Oct 27, 2008
All it needed was to clean the orifices of the plug as suggested in the first entry. Just the bit of wire in a twist tie. :-)
Posted on Jun 22, 2010
3 Suggested Answers
SOURCE:
SOURCE: I have a 22 in Recycler Lawn Mower. I haven't had ...
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
Posted on May 22, 2010
  • 8404 Answers
SOURCE: Toro self propelled mower rear wheel keeps falling off
Are these regular bolt on wheels? Have you changed the nut?
I would expectc to find a "Stover" nut on such an appllication. Stover nuts are similar to "NY-Lock" but without the nylon lock. Rather, Stover (and you have to ask for them at the hardware or auto parts place), are not round and/or have had a certain side portion punched to make the nut hard to put on. Some well meaning back yard mechanics (read me) have 'fixed' the Stover by running a tap through them maning them easier to get onto the threads ... but alas, it didnt stay. That was how I learned about Stover.
Let me know if this helps.
A
Posted on Sep 21, 2009
How to remove spark plug
I have attached an article about how to change the spark plug on a walk behind mower.
The directions should be roughly the same despite the difference in brand and model.
I hope this helps!
How to Change the Spark Plug on Toro Recycler Self Propelled Mower
May 05, 2014 | Mtd 22" Yard Machine Push Mower
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
Aug 18, 2011 | Toro Power Lawn Mower
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
My toro self propelled only runs for a few minutes. I replaced air filter and spark plug, and cleaned out carb. Any ideas?
Have you tried replacing the gas cap? I had the same problem with my mower and did everything you have done, changed gas cap no problem since
Jul 25, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
45,882 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
roeb
Are you a Toro Garden Expert? Answer questions, earn points and help others
