I hooked first network printer so easily. I manually entered IP address and all was well. Printed a config report and there is no IPv6 Address. The second printer I tried to set up I did the same thing, but IPV6 shows an address and I can't get it to print. Tried a 3rd and it also shows IPv6 address.
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
