Just clean the rollers this works for me canon ink cartridges
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: Canon MX300 Paper Jam alarm
Forcing a piece of cardstock as far into the feed as I could, then removing it fixed this problem for me.
Hopefully it will work for you!
SOURCE: my canon MP258 show error
That is due to the clear plastic strips inside the printer, the one that run behind the cartridge holder, being dirty or damaged.
This plastic strip with black marking on it, is used to tell the printer where the cartridges actually are.
Unfortunately it could also be the sensor that reads this strip being damaged.
Inspect the strip with a bright torch to see if any ink or dirt is on this strip, use a bright torch when doing so, it makes it much easier. Also check behind the cartridge holder for any torn bits of paper that could be jammed in it.
Make sure the printer is unplugged from the power during this!!
I hope this helps
Regards GM
SOURCE: canon mp250 E03 code but
Take all of the paper out and turn it off then back on again. If this does not work take all of the ink out of it and do the same thing.
remark to check black colour
