Question about Coleman Powermate 27 Gallon Air Compressor
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop running. KWS
    New Friend:
  • 90 Answers
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Posted on Nov 19, 2011
  • Konrad Scheel Nov 19, 2011
    From parts manual the "switch, pressure" number is 0340135
    And that is for a Coleman Powermate L052710
  • Calvin Smith
    Calvin Smith Nov 21, 2011
    I would go ahead and order the pressure switch. Make sure to leave the old one hooked up until your new one is ready to go on, then once your new one arrives, take the wires off of the old one and put them in the correlating spots on the new one. This should solve your problem.
    Calvin Smith
6ya staff
SOURCE:
Will a air compressor that runs at 11.8 cfm at 90 psi run at 10 cfm at 100 psi?
if it is a 11cfm compressor then it produces 11.8 cfm of air regardless of the pressure
pressure has nothing to do with cfm but with the restriction to air flow
for example the tire inflator -air hawk- has a very small cfm but as the tire restrict the air flow the pressure builds up to set pressure on the gauge
so if you want 100psi from the 11.8cfm unit just adjust the pressure switch to shut off at 100psi
Cfm is only important when using air tools as a compressor that is not capable of maintaining the cfm thereby the pressure to run the tools is not a good idea
as an example
a sand blaster that uses 11.8 cfm at 100 psi will not work on your compressor
that unit will require a 20cfm compressor to run it peoperly
Sep 25, 2017 | Psi Air Tools & Compressors
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
I HAVE A 4 HP GAS COLEMAN POWERMATE COMPRESSOR. THE COMPRESSOR KEEPS RUNNING AND WONT SHUT THE PRESSURE OFF UNTIL THE BLOWOUT VALVE BLOWS.THIS COMPRESSOR HAS A HONDA 4 HP GAS ENGINE ON IT.THE PRESSURE IS...
Coleman PowerMate CT4090410 Operator Parts Manual
This unit uses an loader valve to control pressure, it will unload compressor and idle engine back until the pressure falls below 95 psig and the speeds engine up and loads compressor until cutout pressure is reached. I've linked to manual and the unloader is
Coleman PowerMate CT4090410 Operator Parts Manual Page 18
The item number is 9 and part number is 070-0056.. This part is around $100-$110. Ive repaired this type part on air compressors used on mechanics service trucks ., Depending on your skill level and access to tools and parts, it might be better to purchase a new one.g take time ti read to read and understand manual. Good luck
Nov 10, 2017 | Coleman Air Tools & Compressors
Compressor pressure only to 60 lb psi and no more
not sure but it sounds like the piston ring is worn out or you might have a bad valve.
p.s. its not your typical valve like in a car.
is it a wet compressor, check the oil.
Feb 21, 2010 | Coleman Powermate 27 Gallon Air Compressor
What settings do I use for the VP201 compressor
Leave the compressor setting to the highest level.The other guage is to regulate the pressure output.For example if you need 40 PSI turn this regulator until this output is reached
Oct 08, 2009 | Coleman Air Tools & Compressors
The pressure reads 40 psi on both guages on this
with it running check regulator knob .it pulls up turn right pressure should go up.if not regulator bad
Jun 20, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Jan 10, 2009 | Coleman Powermate 27 Gallon Air Compressor
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Oct 28, 2008 | Coleman Powermate 02 - Gallon Air...
Coleman Powermate 27 Gallon Air Compressor Logo
253 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
