There are spring clips in the rear axle just behind the rear wheels. Yours are either no engaging properly or missing completely! Check page 20 of the manual. By the way you are my 500th solution!
www.pramfix.com.au/baby_repairs_spares/instruction_booklets/Bugaboo%20Frog%20with%20diagrams%202004%20Pram.pdf
Yes, you're right. The clips are there and I've tried to have a play with them but to no avail! Thank you for attaching the booklet but unfortunately it isn't that clear how they should go if I were to take the whole thing apart. Any step by step instructions for your 500th customer??!!! Many thanks :o)
The plastic wheel stub should just push into the aluminum axle, as the stub reaches the clip the tapered end should open the clip out, after the tapper is a groove the clip should drop into that and lock the wheel on. The wheel should only come off again by pressing the two clip ends together opening the clip. Check the groove it might have something in it.
