C5102 Description: Main motor malfunction • The main motor (M1) lock signal remains HIGH for a continuous 1-sec. period at any time 1 sec. after the main motor has started turning.
Causes: Main motor (M1) Printer control board (PRCB) DC power supply (DCPU)
Remedy: 1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary. 2 Check M1 for correct drive coupling and correct as necessary. 3 M1 operation check. PRCB CN6-7 (LOCK) 9-D 4 Change PRCB. 5 Change DCPU.
CC102 Description: Controller - engine connection failure • The engine control system can not communicate with the controller.
Causes: Printer control board (PRCB)
Remedy: 1 Turn OFF and ON the power switch. 2 Change PRCB.
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start. Good luck!
Press Utility / Counter -> {STOP}{0}{0}{STOP}{0}{1}, now you should be in Service Mode. Go to Service Choice - > IU LIFE STOP MODE -> and choose CONTINUOUS.
