Belling XOU174 Electric Single Oven Logo
Posted on Sep 28, 2008
WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
I am wiring an electric cooker to the wall we have three colors just want to make sure we put the right color in the right hole in the wall..... The unit on the wall has three symbols E L & N, and then on the cable from the cooker we have three colors yellew/green , brown and blue... Can you help please Thanks and best regards
  • Anonymous Feb 19, 2009
    i dont no what colour wire goes were
  • Anonymous May 14, 2009
    i have taken the wire from the old cooker need to conect to the new one
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
6515
Points
6
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
A
Anonymous
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7967
Points
BLUNTLY but with all due respect if you dont know this you should not be doing it. You will kill yourself or someone else some day!! This is why the law ( ref.competent person ) requires you to use an electrician. You have just shown why you are not competent.
Oven will not heat up after using autoclean.
If you have a problem with your whirlpool cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
2answers
Have wall oven will not heat everything else is working what is wrong
If you have a problem with your Frigidaire cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
How to Repair
Buy Paul Beer
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
1helpful
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Can you tell me where the wires go on electric cooker the colours are blue,copper,brown done know which wire goes where ,to the left middle, right
When you say electric cooker are you talking about an element or the whole oven unit. I can help but need more details.
Mar 02, 2011 • Ovens
2helpful
2answers
Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Dec 07, 2008 • Ovens
2answers
Electrical connections on indesit cooker
Is it just a 2 wire connection element?
Feb 29, 2008 • Ovens
Top Belling Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Belling Oven Expert? Answer questions, earn points and help others
