I have LAVAMAT W 1020 waching machine. After completion of the rinse stage the spin does not work. I tries all 3 spin positions, 6, 8, 11 with no success.
E52 is a motor fault, i.e. motor not turning or tachometer is faulty. It is most likely that the carbon brushes are worn out and need replacing. These are readily available online
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
I have same problem right now. The machine works fine up to the stage where it needs to pump out. the pump was dead. Have replaced the pump, but still not working and it's probably the PCB that needs replacing - expensive but will buy reconditioned for about £50.
Pump available for the machine on Ebay and easy to replace. Take of machine back panel - make sure machine off and unplugged. Pump has 3 screws holding it in - then just replace. Easy. Good luck
there is a safety switch on the top...and when you close the lid it pushes down on that switch. investigate that switch and see if its just corroded or needs replacement...i have that same problem when i leave the lid open on my washer...then it works fine when i close it...so im figuring that your's thinks its still open. I hope this helps you out ! and give your wife a hug 8-)
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
