I have checked power supply and all three voltages (12, 5 and 3.5) are right on. Jim Hagen discusses replacing 9 capacitors in the power supply and two in the logic board. Since the power supply seems okay, should I skip the 9 and just do the two on the logic board? Where can I get advise on replacing the logic board caps? I have replaced the more common types as used in the power supply, but these look tricky.
I followed your advise in replacing the power supply caps and you are absolutely right, the unit works fine now. I had checked the power supply voltages with the power supply unconnected to the logic board, finding them to be perfect; but when the logic board was connected the voltages were way off. The 12 and 5 volt outputs were high and the 3.3 volt was low.
I decided not to touch the logic board caps as the unit works now. Thank you very much for the expert advise, Jim.
I bought my caps from badcaps.net. Reasonable prices and great service. Only problem: I couldn't find the 1uF caps that Jim Hagen recommends replacing. At this point it, and the 22uF, 400 volt cap, have not been replaced. I will replace the 1uF when I get one, as a matter of preventive maintenance.
I have come to reconciliation with the CM-7000. The receiver has excellent sensitivity and, while I'm no electronics engineer, it appears to be quite sophisticated in design. It seems to me that this manufacturer was torpedoed by bad capacitors, as have a lot of others. There are web sites that go into detail about this problem.
Once again: Thank you, Jim.I followed your advise in replacing the power supply caps and you are absolutely right, the unit works fine now. I had checked the power supply voltages with the power supply unconnected to the logic board, finding them to be perfect; but when the logic board was connected the voltages were way off. The 12 and 5 volt outputs were high and the 3.3 volt was low.
You can't post conmments that contain an email address.
On all units that I repair, I replace all nine of the power supply board capacitors regardless of the voltages. There are poor quality capacitors and are going to fail at some time in the future. The logic board caps are the same through hole type as the power supply. Yes there are many surface mount capacitors but none of these have need to be replaced. Replacing the logic board caps are very difficult because of the inner plane layer that acts like a giant heat sink. I use a desoldering station that has a suction pump and set the temperature to 850 degrees F. First I unsolder the square pad lead as this one is easy. The other lead requires more time, I hold the iron on until I can move the capacitor lead and turn on the suction as I pull the part out of the hole. Even with this process the holes do not always come clean and require additional work. Without the desoldering station it is very difficult and I would not recommend attempting it.
I have this exact same issue. How would I go about having it repaired by an expert?I have this exact same issue. How would I go about having it repaired by an expert?
I do have the exact same issue. How may I have it repaired by you or another expert?.. Thanks.I do have the exact same issue. How may I have it repaired by you or another expert?.. Thanks.
Although replacing every aluminum electrolytic in sight is likely to bring a CM-7000 back to life, in my experience the only capacitors that have failed, in four different units, have been
E5, E6 on main board -- one unit
C12 on power supply -- three units
E1 is a 100 uF 16 VDC capacitor. I have been repairing these units lately and have experienced some of the same symptoms (LED goes red but doesn't transition to green after 30 seconds like it should). I have been able to repair some of these units. Make sure the power supply is working properly before spending significant time on the D2A board. The power supply is responsible for supplying 12, 5, and 3.3 VDC to the D2A board. A defective PS will measure 14.5 instead of 12, 6 instead of 5, and 2.9 instead of 3.3. The AC ripple should be about 5 mV on the 3.3 and the 5 volt supplies when loaded. The 12 volt can be as high as 50 mV on a good PS. The culprits are C12 (1000uf) and C10 (470 uf) which are the filter capacitors for the 3.3 and 5V outputs respectively. C12, the capacitor for the 3.3 V output is especially critical because it is used to feed the voltage regulator and overvoltage shutdown circuit. D7 is a hot part and can also fail sometimes. I have repaired 50% of my units just by changing these capacitors. I still have units where the D2A board is bad with a known good power supply. If anyone has more info on the D2A (like a schematic) please pass it along
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.
On the power supply I would replace at a minimum: C14 - 4.7ufd 50v UPW1H4R7MDD C4 - 1ufd 50v UPW1H010MDD C8 - 100ufd 25v UHE1E101MED C10 - 470ufd 16v UHE1C471MPD C12 - 1000ufd 10v UHE1A102MPD
There are 4 others in the supply that were not grossly bad. C1 - 22ufd 400v EEU-EE2G220 C7 - 220ufd 25v UHE1E221MPD C11 - Same as C10 C13 - Same as C10
Logic board: E5 - 33uf 35v EEU-FM1A471 E6 - Same as E5
Part Numbers of replacement caps are Nichicon or Panasonic.
Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.
Contact me if this is beyond your skills for possible repair.
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
First look at the indicator lamp on the front left side. If it is: off - check the power cord is plugged into a working outlet. Amber - the unit is in standby, press the on button (left most), it should turn green Green - the unit is in operate mode, check the antenna and cable connection. Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
1) Inside of computer is dirty, as well as the inside of the Power Supply.
Dirt, dust, etc, can cause the cooling components capacity to drop tremendously. If the Processor overheats, it is turned off. (BIOS turns it off)
This is a Fail Safe feature that is built-in, to keep the Processor from burning up. (Literally)
A non- working Processor fan, or one that works intermittently, or doesn't spin as fast as it's supposed to, will also cause the Processor to overheat.
The major cause of computer failure, is that the computer, (And Power Supply) is dirty inside.
Solution is to have the computer unplugged from power, computer case open, use a can of compressed air for computers, and clean the inside of the computer, PLUS the inside of the Power Supply.
(Read about Anti-Static precautions below, BEFORE you do)
2) Power Supply is bad. Weak voltage power rail, brought about by failing components inside the Power Supply.
Test the Power Supply for voltages. Computer power supply's, supply three main voltages. A) 3.3 Volts B) 5 Volts C) 12 Volts
[Orange insulated wires are 3.3 Volt. Red wires are 5 Volt. Yellow wires are 12 Volt. ANY Black wire is a Ground wire]
This test can be done with an inexpensive multimeter, or a Power Supply Tester.
The Positive (Red) probe lead of the multimeter, is connected to the power wire to be tested. The Negative (Black) probe lead is touched to any Ground wire.
The 12 Volt power can be 11 to 13 Volts. Below 11 Volts it's time to replace the Power Supply.
This is one example of an inexpensive, easy to use Power Supply Tester,
Or, a compatible, KNOWN to be good power supply, can be substituted, and used for a test unit.
3) Electrolytic Capacitors are failing on the motherboard. Specifically, the ones used in the motherboard Voltage Regulator Circuit.
One of the jobs the Voltage Regulator Circuit does, is to regulate voltage for the Processor. A Processor must have a Steady, Clean, supply of voltage, and the voltage MUST be kept within a certain range.
This range, or Tolerance Zone, is VERY small. Too little voltage the Processor turns off. (No Processor operating, No computer)
Look for obvious signs of capacitor, (Electrolytic Capacitor) failure.
Solution is to replace failing, or failed Electrolytic Capacitors, or replace the motherboard.
To summarize:
1) Check to see if the computer is dirty. If so, unplug from power, open the computer case, use a can, or two of compressed air for computers.
2) Visually inspect for bad capacitors. (BEFORE reaching inside a computer, have the computer unplugged from power. Observe Anti-Static precautions.
Your body carries Static electricity. Static WILL fry out {Short Circuit} the hardware components inside a computer.
Work on a table. Computer Unplugged from power. Computer case open, TOUCH the metal frame to relieve your body of Static.
SHOULD you get up, walk away, then return, TOUCH the metal frame again)
3) Test the voltages of the power supply, or use a KNOWN to be good, compatible power supply for a test.
NOTE* The Power Supply may light lights, and spin fans. It may even sound as though the Harddrive is running. However if the Power Supply has a weak voltage power rail, there won't be enough power to turn the Processor on.
A) All the lights use less than 1 Watt of power. B) EACH fan uses 2 to 3 Watts.
C) A typical Processor can use anywhere from 51 to 125 Watts. Depends on what Processor it is.
No Processor operating, the Harddrive just sits there, and spins the Platters inside.
There is no Processor to find the boot sector located on the Harddrive. That's why it sounds like the Harddrive is operating, but in reality it isn't.
Read this to know how a Harddrive is made up, and about the Platters I referenced to above,
Check the power supply circuit. Typical voltage at B+ is 105V. Chances are that it is much lower. Check (as you say), capacitors on the primary circuit of the SMPS. Better still, replace all low voltage capacitors within the power supply.
