My Viking DFUD042 stuck in drain cycle. Paid repairmamn $225 to come out and tell me that I needed a new pump, but I'm skeptical. he dried up the pan which had water, and did something to make the pump stop. After he left I restarted and it rinsed, drained, but when the cycle was over...same thing, pan filled with water and pump stays on. don't know how to turn off. it stays off when the breaker is thrown but pump comes right back on when breaker is switched back on???? would like to fix myself if possible.
SOURCE: My Viking DFUD042 is stuck
Hi, this could be a bad control board or a bad motor. It uses the same motor to wash as to drain. It just changes the direction of the motor in order to switch from drain to wash.
You'll need to run a cycle and you will need a multimeter to check which one needs to be replaced. Remove the kick panel and check the grey wire to the ground wire when it should be washing. If you have 120 volts, you need to order and replace your control board. Otherwise, if you don't have power and it's still draining, you need to order and replace the motor.
