Samsung  50 in. Plasma TV Logo
steve parker Posted on Nov 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Virgin remote control code for volume on my 50" samsung plasma tv
Anonymous
Level 3:
  • Master 380 Answers
  • Posted on Nov 18, 2011
Anonymous
Master
Level 3:
Answers
380
Questions
0
Helped
102714
Points
1118
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
4helpful
3answers
I need a code list for my remote set top box...it is for a panasonic viera 32inch lcd flat panel television.
Hello zaninc and welcome to FixYa. I'm not sure if you are referring to the codes for your cable box or your actual television so I have provided codes for both.
Panasonic Television Codes
0051, 0055, 0250
Panasonic Cable Box Codes
0000, 0107, 0021
Note if your remote control only accepts three digit codes you will have to take the first zero off of the codes that I have provided in order for them to work.
If these codes do not work for you please inform me of what make and model of set top box you own using the comments box and I will get right back to you. Thank you for using FixYa and good luck zadinc.
3helpful
Need codes where can i find them
To set up the volume control on your virgin remote control, to be able to change the TV volume, please follow the instructions below.
TV Codes
Akai 0236, 0544, 0630
Alba 0037, 0065, 0246
Amstrad 0205, 0440, 0065
Bush 0246, 0263, 0377
Decca 0064, 0100, 0544
Ferguson 0101, 0363, 0221
Fidelity 0244, 0221, 0460
Finlandia 0374, 0387, 0236
Goodmans 0065, 0064, 0100
Granada 0379, 0387, 0391
Grundig 0563, 0582, 0515
Hinari 0037, 0064, 0065
Hitachi 0253, 0384, 0377
JVC 0681, 0081, 0122
Matsui 0263, 0205, 0037
Mitsubishi 0136, 0382, 0064
NEI 0065, 0365, 0459
Nokia 0508, 0501, 0576
Panasonic 0678, 0254, 0278
Philips 0584, 0065, 0040
Saisho 0039, 0205, 0263
Sanyo 0236, 0073, 0100
Sharp 0121, 0064, 0065
Sony 0533, 0038, 0039
Tatung 0065, 0100, 0544
Thomson 0363, 0653, 0137
Toshiba 0536, 0063, 0271
If I have not listed your make of TV in the table above,
1. Press to go to the Home Screen.
2. Choose Telewest Services.
3. Choose Technical Assistance.
4. Choose TV Control Codes.
5. A full list of TV brand codes will appear.
If the volume control is still not working after trying all the codes for your TV model, or your TV model is not listed, then your TV is not compatible with our remote control and you will need to use your TV remote to control the volume as normal.
You can also use your TV remote control to adjust the volume in the normal way. Good Luck
11helpful
Volume button doesnt work on my sky remote
please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
I need the remotev codes for samsung
i need your remote control model number.  or you can get your original remote control part from www.replacementremotes.com
2helpful
Virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
1helpful
Samsung le37a456c2d
For the V+ remote control (Virgin Media have a picture of it here - http://www.virginmedia.com/images/types7-8n.jpg - the code is 0079.
2helpful
2answers
2answers
Virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
