Hi.
If the washer does not agitate and spin, then the most common problem is the belt: Washer Drive V-Belt (part 28 in diagram 1)
If you can manually advance to spin but the machine does not agitate, then parts that may need to be replaced are the agitator:
Agitator (part 11 in diag 1) or the agitator drive in the transmission:Agitator Drive (pt.2 diagram 2)
To replace the belt remove the assembly at front top of the washer held by two philips screws and clips. Here description of replacement procedure.
Here Diagram 1
Here Diagram 2
Regards.
Ginko
Good Afternoon Sarah, thanks for your post!
From the information you have provided the washer on your Frigidaire laundry center will not agitate or spin and will drain. This sounds like a possible issue with your motor or belt. In order to pinpoint the issue with your washer you may need to disassemble the washer and test each component for electrical issues and cosmetic damage. This is not a simple DIY job and I would recommend you speak with a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
