Gaggia Titanium Espresso Machine Logo
Zoe Ashley Posted on May 16, 2017
Gaggia titanuim brewunit blocked
Machine is displying the brewunit blocked message. I removed the unit and reset the dial so that it is in the neutral position. I then used the card bypass trick to attempt to reset the cog to the normal position. The machine sounds as if it is trying to turn the cog but nothing happens and then get the unit blocked message again. In addition, the unit will not go back into position within the machine, probably because the cog is not in the correct position?. What is the next step? (I miss my coffee:( ) Thanks Zoe
  • David Holmes
    David Holmes Nov 10, 2017
    I have exactly the same problem. Did you manage to get it fixed?
5 Related Answers
Anonymous
  • Posted on Dec 30, 2008
SOURCE: Gaggia Synchrony Brew Unit Block
Your machine has stopped mid-cycle.
1. Open the brew group door and look for a screw holding the the coupling to the water inlet, lower left side of the brew group. Remove the screw with a phillipshead screwdriver.
2. Remove the brewgroup by holding the handle and pressing on the "press" button. The brew group will slide out.
3. Remove the water inlet piece left behind from the machine and re-attach it to the brewgroup.
4. Now you must reset the machine. Bypass the three microswitches to the door, the dump box and the brew group by taping them down. Once they are all bypassed the unit will move the gears to the correct position with the two larger cams on top.
Put in your brew group and you are good to go.
If this problem persists you need to send it in for service.
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Apr 27, 2009
SOURCE: Hi I have a gaggia titanium coffee machine it has
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Anonymous
  • 1089 Answers
  • Posted on Nov 15, 2009
SOURCE: brewunit will not go back in due to the cog and
HI
These are some instructions for your problem.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Testimonial: "excellent advice"
Anonymous
  • Posted on Nov 29, 2009
You have got the gears out of alignment. You don't really want to take out brew group unless at end of cycle. You can fool machine to get brew group back in.
Here is how :
BREW GROUP REMOVAL AND DRIVE GEARS ADJUSTMENT
FOR AUTOMATIC MACHINES
If you ever find yourself in need of removing a Brew Group that has jammed. This will assist you in doing so correctly.
To fix this problem follow these simple steps:
You will need a #1 Philips screwdriver
1.) First, open the door on the machine and remove the drip tray and dredge drawer
2.) Locate the nickel size hole in the brew group. It will have an "N" next to it. At the 9 o'clock position, you will see another hole about 1/3 of the size of the first. Directly behind this hole, or about an inch up depending on the position the machine was stopped in you will see a single philips head screw. You may have to look around the side of the brew group to locate the screw as it is not always visible from the smaller hole. Remove this screw; it holds a small coupling water inlet (it is similar looking to a tobacco pipe) to the brew group.
3.) Remove the brew group by pressing/pushing (depending on your machine) on the part that says “Press" or "Push”. Pull firmly and straight out. Be cautious to not break the brew unit. Also be aware of the door of your machine as it can break as well.
4.) With the brew group out, remove the small coupling water inlet (tobacco pipe) that is probably still stuck to your machine and reinstall it in the brew group as it was before. Make sure the screw is installed snugly but not too tight.
5.) Turn the brew group around so you are facing the back. Now imagine what a check mark looks like, the top we will call position A (longer part of the checkmark) and where the checkmark ends (the smaller portion) is point B. You will notice what looks like a large checkmark where the coupling water inlet is located. The water coupling can slide up and down in this checkmark opening. The water coupling should be in the B position.
REINSTALLING THE BREW GROUP
To do this, the gears will have to be reset to the start position. In order to do so, you will have to bypass the three micro-switches (Brew Group, Dump Box and the Door switch).
Bypassing the micro switches:
1.) Looking at the back-side of the brew group, not the side that says "Push" or "Press," you will notice something fin-like or nose shaped. This piece fits into a keyhole or coin slot looking slot in the machine and that is where the brew unit micro-switch is located. Take something like an index card, envelope, or folded up piece of paper, and insert it into that keyhole so that it will trick the machine into thinking that the brew unit is installed. Start the piece of paper at the top of the slot and slide it to the bottom of the slot. The paper should be thick enough so you can let go and it will remain in place. Leave this object in there until the following steps are complete.
2.) WITHOUT putting the brew group back into the machine, reinstall the drip-tray and dredge drawer and close the door.
3.) After doing so you can then turn the machine ON. At this time the gears will begin moving until they return to the correct start position. At this point remove the object from the keyhole position and you can now reinstall the brew group. If the brew group does not go back in correctly, try a few more times. The machine will return to its home position. Note: The two large spokes of The brew drive shaft should in the Up position
At times, the gears in the brew drive assembly will not complete the cycle to the proper
start position for different reasons. Some of the reasons are:
• Brew group jammed or blocked
• Either one of the micro switches in the brew drive have gone bad.
• Brew drive motor Failure.
• Broken teeth on either of the brew drive gears.
• Dirty brew group, covered by coffee grinds.
• Brew group or gears not lubricated.
• Connections to the board from brew drive assy., or motor have gone bad.
A jammed or blocked brew group happens when the brew group starts the cycle but doesn’t finish it.
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Apr 27, 2010
SOURCE: only just bought a gaggia titanuim on the wend i
I have not seen many problems with the titanium, if yours have the stainless steel steam valve, you should be fine as long as you perform the regular cleanings.
Brew unit blocked
‏Because a non logical reason the error “BREWUNIT BLOCKED” appears also when the cup heating circuit is open... after heater or fuses fails.., ?Gaggia should have informed in the net about this error message as an anomaly .
‏?So, before you change your Brew Unit or you CPU..,, just check continuity between the two yellow wires... and bingo!
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
2helpful
2answers
No matter what I do the Gaggia Titanium espresso machine reads brewunit missing;. This is what I did: I removed the brewunit of the machine to clean it, and reset the N to the correct position on the front...
HI
If the brew unit is in the wrong position when inserted you can knock the lever off the microswitch in the back. If the lever is knocked off you will never get the brw unit miss message to go away. You will have to take the machine apart and replace the lever on the microswitch. Sorry
We made a modification to the brew unit that would prevent this from happening. We modified all the brew units on the compact machines before sending them out so we would never get them back for this reason.
2helpful
2answers
Screen says brewunit blocked. Brewunit seems clear but stops in wrong position, ie not 'home' any ideas? Thanks
Hi If you remove the brew unit and put everything back with out it the brew unit. Turn th machine on and see if it will cycle? Open the door and look in the back where the brew unit was. There is a cog in the back with teeth. There are 2 large teeth, and they should be at the 10 and 12:00 position roughly. If they are anywhere else you have a broken drive and need to get the gears replaced. If they are in the correct position check the front of the brew unit where the circles are. There are 2 diamonds and they should be pointing at each other. if they are not you need to bring them together with the key tool. Insert it into the center of the circles and turn until they line up, then put back into the machine, and see if it will work. If it still doesn't you have a bad board.
Brewunit is blocked
Try giving the brew unit a good clean,if this fails you require a new main board
MESSAGE SAYS BREWUNIT MISSING CANNOT CLEAR
Try taking the brew unit out, and clean the area inside the machine for coffee grains before reinserting it. There's a tiny sensor for if the unit is inserted, but it can be confused if the machine gets messy inside.
Gaggia Titanium, "Brewunit Blocked"
Check the shower screen in the unit it is possible that it is blocked with coffee oils.
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
BrewUnit Blocked Error
The brew unit sensor may have become disconnected from the main circuit board. If you are very brave, you can UNPLUG THE UNIT, remove the top panel and check that all the wires running into the circuit board are connected.
Otherwise, the sensor may have failed and this will require service.
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
